- Thank you received: 11
LinuxCNC Features - a kind of NGCGUI
- tome
FernV wrote:
tome wrote: This error comes up in the terminal where I start Axis:
emc/task/emctask.cc 389: interp_error: Unable to open file <./scripts/features.ngc>
can't open ./scripts/features.ngc
I thought this was solved. Check your lathe.ini file to see where PROGRAM_PREFIX points. It can be a relative path to this file or absolute. Also you may try opening features before LinuxCNC.
I played with PROGRAM_PREFIX but couldn't get any change in behavior. If I start features.py before Linuxcnc (not exactly most convenient) it doesn't complain about this on startup, but if I try to use any of the features I still get this error.
FernV wrote:
tome wrote: PPPS:
If I select Lathe thread i get a G-Code error in features.ngc dialog that says:
Near line 54 of
/home/tom/linuxcnc-features/FernV.../scripts/features.ngc:
Spindle not turning in G76
I did not review lathe routines that I did not write like this one but I found some code was missing. I corrected that and pushed to git but it does not show although git on my computer says files are up to date. The file is ini/lathe/thread-adv.ini but if you want to correct it here how to do it simply :
1- in features do Add -> Threading -> Thread
2- in the table view select and right click on Lathe thread ??? or use Utilities Menu and select "Edit current feature" (it will open the file in your editor)
3- go at the end and replace everything after
[PARAM_FEED]
name = Feed
type = string
icon = icons/tool-feed.png
tool_tip = Feed
value = #<_global_feed>
with
[PARAM_SPINDLE]
name = Spindle Speed
type = int
tool_tip = Spindle speed
value = 400
[CALL]
content =
#<p> = [#param_p]
#<k> = [#param_k]
G0 X#<_global_rappid>
G0 X[#param_x0]
G0 Z[#param_z0]
S#param_spindle M3
G76 P[#param_p] Z[#param_z] I[#param_i] J[#param_j] R[#param_r] K[#param_k] Q[#param_q] H[#param_h] E[#param_e] L[#param_l]
4- save the file
5- in features delete Lathe thread ???
6- reload it with Add -> Threading -> Thread
7- set params to have threads that are OK
Regards
Fern
Well, I made this edit, now when I select that feature I get nothing in the features window and a whole pile of errors in the terminal about parsing errors...
-Tom
Errors:
File "./features.py", line 1171, in catalog_activate
self.add_feature(src)
File "./features.py", line 2423, in add_feature
f = Feature(src_file)
File "./features.py", line 525, in __init__
self.from_src(src)
File "./features.py", line 556, in from_src
src_config.readfp(io.BytesIO(f))
File "/usr/lib/python2.7/ConfigParser.py", line 324, in readfp
self._read(fp, filename)
File "/usr/lib/python2.7/ConfigParser.py", line 546, in _read
raise e
ConfigParser.ParsingError: File contains parsing errors: <???>
[line 122]: 'G0 X#<_global_rappid>\n'
[line 123]: 'G0 X[#param_x0]\n'
[line 124]: 'G0 Z[#param_z0]\n'
[line 126]: 'S#param_spindle M3\n'
[line 128]: 'G76 P[#param_p] Z[#param_z] I[#param_i] J[#param_j] R[#param_r] K[#param_k] Q[#param_q] H[#param_h] E[#param_e] L[#param_l]\n'
tom@EMCO-120P:~/linuxcnc-features/FernV-linuxcnc-features-ba61fd6$
- FernV
- Thank you received: 124
Can you post the ini file you are using when starting linuxcnc ?
Regards
Fern
- tome
FernV wrote: Hi Tom
Regards
Fern
[EMC]
MACHINE = EMCOturn120p
DEBUG = 0
[DISPLAY]
DISPLAY = axis
GLADEVCP = ./EMCO120p-panel.ui -d
LATHE = 1
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
PROGRAM_PREFIX = /home/tom/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.500000
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xz
INTRO_TIME = 5
#USER_COMMAND_FILE = /home/tom/.axisrc
#OPEN_FILE = /home/tom/linuxcnc/nc_files/lathe_pawn.ngc
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
#SUBROUTINE_PATH = /home/tom/linuxcnc-features/subroutines:/home/tom/linuxcnc/nc_files/ngcgui_lib:/home/tom/linuxcnc/nc_files/gcmc_lib:/home/tom/linuxcnc/nc_files/ngcgui_lib/utilitysubs
USER_M_PATH = /home/tom/linuxcnc/myMfiles:/home/tom/linuxcnc/nc_files
# g-code modal codes (modes) that the interpreter is initialized with on startup
# - - - ** See what is in linuxcnc.var!
RS274NGC_STARTUP_CODE = G18 G20 G90
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = EMCOturn120pGlade.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.10
# - - - ** Changed this from MAX_LINEAR_VELOCITY as gmoccapy guy said it’s an old config param…
MAX_VELOCITY = 1.50
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
TOOL_CHANGE_WITH_SPINDLE_ON = 1
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
HOME_SEQUENCE = 0
HOME_SEARCH_VEL = 0.25
HOME_LATCH_VEL = 0.125
HOME_FINAL_VEL = 1
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = NO
HOME_OFFSET = 0
VOLATILE_HOME = 1
#FERROR = 0.5
FERROR = 1
#MIN_FERROR = 0.05
MIN_FERROR = 0.5
MAX_VELOCITY = 1.5
MAX_ACCELERATION = 30.0
STEPGEN_MAXVEL = 1.875
STEPGEN_MAXACCEL = 37.50
# these are in nanoseconds
DIRSETUP = 5000
DIRHOLD = 5000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 10159.9997
MIN_LIMIT = -2.106
MAX_LIMIT = 0.001
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
HOME_SEQUENCE = 1
HOME_FINAL_VEL = 1
HOME_USE_INDEX = NO
HOME_OFFSET = 0
VOLATILE_HOME = 1
#FERROR = 0.5
FERROR = 1
#MIN_FERROR = 0.05
MIN_FERROR = 0.5
MAX_VELOCITY = 1.5
DIRSETUP = 5000
DIRHOLD = 5000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = -10159.9997
MIN_LIMIT = -6.909
MAX_LIMIT = 0.001
# Spindle
[SPINDLE_9]
ENCODER_SCALE = 150.0
- FernV
Thanks for posting your config file.
tome wrote:
And this error comes up in the terminal where I start features.py:
tom@EMCO-120P:~/linuxcnc-features/FernV-linuxcnc-features-ba61fd6$ ./features.py
./features.py:2897: GtkWarning: Failed to set text from markup due to error parsing markup: Error on line 2 char 42: Element 'markup' was closed, but the currently open element is 'D0'
return window.run()
The bug was in the header help of ini/lathe/thread-adv.ini
This following error was when it was not able to create the file (it also happenned with full path)
I hope I solved it for good
About the last error you mention, make sure your file looks like ini/lathe/thread-adv.ini on github
I updated the modified files
There are not too many examples for lathe in linuxcnc/nc_files/examples and I had not much chance to play with it but I will do later.
BTW have you tried with mill config ?
Regards
Fern
P.S. So far, nothing interesting with gmoccapy
- ctbenergy
I tested Features-V2 embedded in Gmoccapy (LinuxCNC 2.7).
1. Clone Git Repo " github.com/FernV/linuxcnc-features.git " into ~/
2. Copy all files from ~/linuxcnc/configs/sim.gmoccapy" into "~/linuxcnc-features
3. Make this settings in the ini file
[DISPLAY]
DISPLAY = gmoccapy
EMBED_TAB_NAME = features
EMBED_TAB_LOCATION = box_right
EMBED_TAB_COMMAND = gladevcp -x {XID} -U --catalog=mill features.ui
[RS274NGC]
SUBROUTINE_PATH = ./macros:./lib:./scripts
- ctbenergy
How can i change from default inches to default metric?
