- Thank you received: 11
LinuxCNC Features - a kind of NGCGUI
- Nick
I'm not sure about last version, I think than those ini have been moved to another folder.... probably they should be removed from the catalog...Sorry, have you no comments to
Norberti just cloned the repo and after starting linuxcnc / gmoccapy I entered ./features --catalog /path to lathe.xml --ini /home/path to ini, I get a list of bugs, that INI files could not be found, because they are searched in subfolder draw. That Folder does not exist, I needed to rename the folder draw-old-delete-later to get rid of the mistakes., but still some ini files are not found, like lathe-multipass.ini, array.ini and circular-aray.ini, as the are not in the lathe folder.
- FernV
- Thank you received: 124
I did not have much time lately to work on the new version, however I completed debugging (only one bug I could not find a work around).
I updated most of my features to take advantage of the new version.
You can see an ellipse and a polygon that is pocketed.
All my features (Rectangle, circle, slots, radial slots, ellipse and polygons) can be cutted clockwise or counter-clockwise, cutted inside or pocket, outside or without compensation.
Here is the general help file (Sorry, it would not upload)
I am willing to share all my work but am not very familiar with git-hub. However I think I have an account.
What do you say about this ?
Regards
Fern
- Nick
Where can we get it?
- aventtini
- Visitor
- tome
-Tom
ps: should add that I am running 2.7.0~pre6
- Nick
GLADEVCP = -U --catalog=catalogs/lathe.xml features.ui
