NativeCAM is Features renamed
9 years 11 months ago - 9 years 11 months ago #83316 by FernV
Replied by FernV on topic Lead in set up
grijalvap wrote: my set up has stand alone THC controller, the process is as following.
-At M3 the THC start the material detect process
-unless the material is detected it go back to the piercing high
-start the arc,
-wait for the piercing time,
-send the arc ok signal LinuxCNC
-LinuxCNC start moving
So the THC does the Z movement to detect material and set compensation for material height, isn't it ?
In such case all is needed is the delay after M3, right ?
grijalvap wrote: in the other hand if the THC is implemented in LinuxCNC
most of the times all this process is made in a sub-routine
in both cases, all this code can be inserted as pre-amble and post-amble.
Then in Preferences dialog, the choice should be made as per machine setup to use a THC controller or a subroutines like mentionned at wiki.linuxcnc.org/cgi-bin/wiki.pl?GmoccapyPlasma am I right ?
Regards
Fern
P.S. After reaching the last coords point of a shape, can we just issue M5 or is it really necessary to lead-out first then M5 ?
Last edit: 9 years 11 months ago by FernV. Reason: Added PS
9 years 11 months ago #83322 by grijalvap
Replied by grijalvap on topic Lead in set up
correct for the first question
The second question answer is we use an
M3 to start THC
M66 P0 Qxx to wait until arc ok is ready
and the last question
is correct this can be very helpful
The following user(s) said Thank You: FernV
9 years 11 months ago #83323 by gmouer
Hi Fern,
I have NativeCAM working embedded by launching it from the terminal like the instructions show. I first change to the NativeCAM directory then enter the command you show for mill.ini, linuxcnc with NativeCAM launches nicely.
What I would like to do, and have not had any success is to create a desktop launcher to do this so I don't have to open terminal, change directories and enter the starting command every time. I have not had any luck getting this to work. I believe its a matter of paths to the various files not being found.
Any suggestions on creating a desktop launcher for embedded NativeCAM?
Thanks,
George
9 years 11 months ago #83329 by FernV
Replied by FernV on topic NativeCAM is Features renamed
gmouer wrote: Any suggestions on creating a desktop launcher for embedded NativeCAM?
It is not very difficult. Right click anywhere on your Desktop and select 'Create Launcher...'
Fill like this
For the icon, select a file like this
Fern
9 years 11 months ago #83335 by tommylight
Replied by tommylight on topic Lead in set up
FernV wrote:
tommylight wrote: Well that is correct, in most plasma setups you do not need anything related to z axis, but i know for sure the configs i use do not care if there are Z related codes or not. Some configs do use Z axis, so it is not advisable to remove it completly. Having a button to include or remove Z axis related code would be best.
This option should be set in Preferences dialog. Not sure yet how this exclusion should be implemented how it would work. All videos I viewed use some way of finding the surface.
tommylight wrote: The configs that do use Z also use some type of G38.x move to find the material and set offsets for every cut so that would need to be added as a preamble that can be edited to suit the needs of different setups. This can be done together with adding M3/M5 to every cut.
The G38.x option should also be set once in the Preferences dialog
Do you think wiki.linuxcnc.org/cgi-bin/wiki.pl?Gmoccapy_Plasma should be my starting point ?
tommylight wrote: Another thing that can be added for plasma use is adding a G04 pause after the M3, that is a pierce delay, and needs to be adjustable in 0.1 second increments from 0 to 1 second ( even more if cutting thick material ).
I think adding this delay should be in 'Cutting Params'
Anything else should be configured ?
I am planning a video but I still need more feedback to help make it really usable.
I think of demo configs using gmoccappy.gmoccapy_plasma and by_interface.mesa.plasma-5i20.
Regards
Fern
Gmoccapy_plasma is a very nice starting point, it has most information on plasma control in one place.
I also read somewhere here about having a lead out from the cut, it would be nice to have it, as the plasma cutters have a nasty habit of "blowback" when they are switched off and shutting the arc, they tend to leave a nice ding ( burn a bit more material that during normal cutting, and the torch is at stand still while switching off), so adding 2-3mm of lead out would provide for cleaner cuts at the start/stop of the cut.
As for videos, have a look at some of mine, they all use a hal implementation done by someone on this forum a long time ago, and it took me quite some time to modify and make it work for all simple THC that use UP/DOWN/ARCOK signals. This is the method described in the gmoccapy_plasma wiki as being to complicated ( and it is to complicated ). Another method mentioned there is a hal component, there is already one made by BigJT for use with THCAD or other THC, it is much easier to modify and understand but if i remember correctly that still needs a sub for finding the material.
It would be nice to have a comp for automating the procedure of finding the material/retracting to pierce height/firing the torch/waiting for arc ok/waiting for pierce delay/moving to cutting height/enable motion. That can be implemented easily in any config by halcompile and a line in the ini file. This also removes the need for any related Z axis code.
From your stand point, i think you already have everything needed, so just to sum it up:
M3/M5 for every cut
Lead in/out for every cut with the inside/outside option for every cut or for all at once
No Z axis values
Kerf compensation ( tool compensation) also with inside/outside option
Preamble and postamble as needed and subs for every cut
Nothing more, as it would make some things easier for some user but more complicated for others.
9 years 11 months ago #83369 by gmouer
Hi Fern,
Thanks for the great help in creating a desktop launcher to NativeCAM. It worked great !
I had the process right before your help BUT for some reason I insist on spelling ncam as nccam ! Obviously that causes problems !
Also, I successfully set up a config with NativeCAM for my bridgeport mill. I look very forward to learning it and using NativeCAM on a regular basis.
Thanks so much for all your work and help.
George
Time to create page: 0.331 seconds
