- Thank you received: 9
FernV wrote: Hi George
So far it looks good (except I should have setup.py print a message when nothing needed to be cleared)
Continue now with the next step : sudo python setup.py
THE RESULT OF THIS IS CRUCIAL AND IT IS WHERE A PROBLEM MIGHT BE.
By the way, what is your Linux distribution and version ?
Fern
grijalvap wrote: i'm using the plasma setup, however when i crete any shape i do not see any lead in it
is anything mising on the set up?
FernV wrote: To George,
It is strange that you have ncam_demo in your launcher ??? I think it had to be putted there in your lcnc distribution which is a pre-release as : 'LINUXCNC - 2.8.0-pre1-2761-g2b678aa' and I believe that is why you have the
'./core_sim.hal:28: Pin 'axis.0.motor-pos-cmd' does not exist' error.
In a terminal type : 'locate ncam.py' to see if there are other copies on your pc
Anyway, you can now familiarize yourself by loading examples and test them.
Do not forget that you have to select the right order
- Workpiece
- Tool change
- Tasks for the selected tool
Fern
