NativeCAM is Features renamed
9 years 11 months ago #82574 by rodw
Replied by rodw on topic NativeCAM is Features renamed
FernV wrote: I have heard of "Lead in" and "Lead out" but was not aware of the meaning
Regards
Fern
For what its worth, if you download the demo version of Sheetcam, and load a DXF file, it will show a couple of different leadin methods, show them on the screen and generate the Gcode. The demo version has a limit to the number of lines of code generated but it will be enough for demonstration purposes. Most leadins I see are an arc rather than a straight line so you don't get problems on the corners.
9 years 11 months ago #82575 by gmouer
It might be worth mentioning that lead-in and lead-out is also used for milling, its not just a plasma thing.
9 years 11 months ago - 9 years 11 months ago #82708 by FernV
Replied by FernV on topic NativeCAM is Features renamed
eFalegname wrote: Hi Fern, yes I tried it unfortunately :sick: , this is the latest version...
If the latest update does not solve the issue, we will have to hard-code the sub-directories
Run setup first then lcnc with ncam embedded
Regards
Fern
Last edit: 9 years 11 months ago by FernV.
9 years 11 months ago - 9 years 11 months ago #82712 by eFalegname
Regards
Fern
Hi Fern, I begin to worry, it is not resolved in any way...
File Name: lcnc2.7.8N...date.txt
File Size:4.11 KB
Cheers,
Floris
Last edit: 9 years 11 months ago by eFalegname.
9 years 11 months ago - 9 years 11 months ago #82784 by FernV
Hi Floris
I see the problem is not what I expected (I was unable to view your video until this morning)
I also see that even with the previous version it 'works' except it does not refresh automatically. I started to have this problem last week and the message on my pc is :
"target application died or uses a Tk version before 4.0"
I will see what needs to be updated. Your file does not show that message.
However, if you use lcnc menu file->open, you should be able to load you project ngc file
Regards
Fern
PS
I just tried gmoccapy and it works perfectly for me, what about you ? Maybe the issue is with axis-remote.
I also note that you were not able to edit preferences. Retry with the latest ncam version I just pushedand you may notice some preference values not loaded. Don't give up
Last edit: 9 years 11 months ago by FernV. Reason: Added some remarks
9 years 11 months ago #82818 by FernV
Hi Floris,
I just upgraded to lcnc 2.7.8 and changes are reflected immediately in lcnc simulator, no more "target application died or uses a Tk version before 4.0" message. Really do not know why your's do not work properly
Fern
