NativeCAM is Features renamed
10 years 1 week ago - 10 years 1 week ago #81948 by eFalegname
Fern, Good morning!,
I did the downgrade to Ubuntu 10.4 and now I can not install NativeCAM, I recorded a video to illustrate the problems I found when I'm trying to run it. Any idea on what I'm doing wrong?
this morning NativeCAM doesn't load at all, I added the log from the terminal below.
File Name: NativeCAMlog.txt
File Size:1.47 KB
Last edit: 10 years 1 week ago by eFalegname.
10 years 1 week ago #81951 by vmihalca
I might be wrong, but from the log I see that python is not installed, I think you should run the command that installs python.
10 years 1 week ago #81952 by eFalegname
vmihalca wrote: I might be wrong, but from the log I see that python is not installed, I think you should run the command that installs python.
Hi vmihalca, that's my python version:
ef@eF900:~$ python Python 2.6.5 (r265:79063, Feb 27 2014, 19:44:14) [GCC 4.4.3] on linux2 Type "help", "copyright", "credits" or "license" for more information. >>>
10 years 1 week ago #81965 by newbynobi
OSError: [Errno 2] File o directory non esistente: '/usr/lib/pymodules/python2.6/gladevcp/catalogs'
IMHO that is the relevant error.
Please check if the file exist on that location.
Norbert
10 years 1 week ago - 10 years 1 week ago #81967 by eFalegname
Thanks newbynobi. I realized that the file does not exist, and in fact I checked and so.
I made several attempts installing and reinstalling NativeCAM, but I would not know how to remedy this situation.
10 years 1 week ago - 10 years 1 week ago #82006 by FernV
Replied by FernV on topic NativeCAM is Features renamed
HI,
This error has been reported to me before. The problem is in setup.py and I will check this when I am back next week.
Since I can not reproduce it I need the messages when you run it with "c" then without
Your log shows : SYS_DIR = /usr/lib/pymodules/python2.6/gladevcp
that is not right it should be : /home/ef/linuxcnc/configs/NativeCAM
I do not know why it is like that please post messages from setup.py
Regards
Fern
Last edit: 10 years 1 week ago by FernV.
Time to create page: 0.131 seconds
