NativeCAM is Features renamed
10 years 2 weeks ago #81744 by vmihalca
I am trying to test the lathe routines for OD turning and I get the error that can be seen in the attachment.
Where do I need to add that global_surface?
I've tried to add a cutting params before the OD turning and this seems to fix the global_surface error but next I get the second error, something about flood. You can see it in the second error message.
Not sure how to fix this so if anyone can give any suggestions, it would be welcomed. Once I figure this issues out, I will add a pull request with the lathe related changes.
I've also attached the ncam.ngc file so that you can have a look over it if needed.
10 years 2 weeks ago #81804 by FernV
Replied by FernV on topic NativeCAM is Features renamed
SvenH wrote: The main question that came up is how to make a circular pocket.
We wanted to remove all the material and ended up making several circles.
It seems that native cam as a system generates the spiral milling path for each circle on some parameters but we could not find how to set those. The inner circle made more passes than the bigger ones.
It worked fine in the end but we'd like to be able to (if possible):
- Just use one command to generate a circular pocket where all material is removed
- Easily set the amount of passes that are made
True spiral mode is not supported yet but on it's way. It has to support all options in the 5 basic shapes. Loop back does and minimize tool chafing too.
In circle.ngc you will find your answers that it starts with a rate of 85% then calc the number of passes by dividing the rest of diameter to not exceed maximim tool engagement you set in Change end mill. You will see tool engagement in terminal window.
Best regards
Fern
10 years 2 weeks ago #81805 by FernV
vmihalca wrote: I am trying to test the lathe routines for OD turning and I get the error that can be seen in the attachment.
You always have to set parameters first
vmihalca wrote: but next I get the second error, something about flood. You can see it in the second error message.
There is a call to a subroutine named <flood> but it does not exist in the file. If not founded, simply comment the line and continue your tests without flood
Fern
10 years 2 weeks ago #81809 by grijalvap
hi
First of all thanks for the great work, the next question is do you have plan to create a plasma version of NativeCAM
there is anything we can help
thanks..
10 years 1 week ago #81820 by FernV
grijalvap wrote: hi
thanks..
I think it should be easy to make a plasma version by the end of next month
I am sure you do not use drills but do you use different tools from your tools table? Any tool width compensation sometimes?
I need to learn how it starts cutting, what is different from milling.
Other than that not many changes are needed, hiding options and setting different default values. ...
Fern
10 years 1 week ago #81821 by rodw
Replied by rodw on topic NativeCAM is Features renamed
FernV wrote:
grijalvap wrote: hi
thanks..
Fern
Looking forward to this one.
BigJohnT is the expert on how to start a plasma cut. Some people will have pneumatic engravers, webcams or laser pointers that would need XY tool offsets but rarely a Z axis offset. (but now somebody will prove me wrong on that!) I have seen commercial plasma's with a drilling head and a tool changer that picks tools lined up along the gantry.
Generally for straight plasma, the tool sets amperage, pierce height, pierce delay and cutting speed based on the material type and thickness thereof. (eg the tool might be 6mm mild steel.
