- Thank you received: 124
absolut15 wrote: Hi fernando.
I only say thank you and wish your and your familie all the best.
After i get nativecam working today , i am sure lcnc gets a lot more atractive because of you and your work.
Have a nice time and greedings from austria.
Florian
newbynobi wrote: My 4.2 mm drill has a tool length offset of -6.25 mm. I touched off with tool 1 (tool length offset = 0), than I loaded tool T7 M6 G43 with offset -6,25 and started the code (just drilling), the tool begins drilling about the tool compensation over the workpiece and thats why it would not go through the workpiece.
Very strange, as If i unload the tool with T0 M6 G49 before starting the code, it is fine.
newbynobi wrote: Next, after finishing the part, I just mounted a new part of material and pressed start again, but then your code moved the zero point of the part! The code finished with the tool in position X90 Y0 and after the restart the position X90 was X0!
newbynobi wrote: Also the tool compensation made strong behaviors.
eFalegname wrote: Hi again Fern,
something went wrong with my update, NativeCAM doesn't work anymore. Could you lend me a hand with it please?
