NativeCAM is Features renamed
9 years 11 months ago - 9 years 11 months ago #83185 by FernV
Replied by FernV on topic NativeCAM is Features renamed
I want you to do this :
  1. Open a terminal in NativeCAM directory
  2. type : ./ncam.py
You should have a result similar to this :
fernand@debian:~/NativeCAM$ ./ncam.py
NativeCAM info:
inifile = NA
SYS_DIR = /home/fernand/NativeCAM
NCAM_DIR = /home/fernand/NativeCAM
program = ./ncam.py
real path = /home/fernand/NativeCAM/ncam.py
Using standard menu.xml, no menu-custom.xml found
Can not find file quick_access.lst
Previous work not saved as current work
No default template saved
Now type or copy : ./ncam.py -iconfigs/sim/axis/ncam_demo/mill.ini
fernand@debian:~/NativeCAM$ ./ncam.py -iconfigs/sim/axis/ncam_demo/mill.ini
NativeCAM info:
inifile = /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/mill.ini
NCAM_DIR = /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam
program = ./ncam.py
Created 3 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/catalogs
Created 69 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/cfg
Created 69 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib
Created 151 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/graphics
Created 5 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/xml
[RS274NGC]SUBROUTINE_PATH = ncam/lib/mill:ncam/lib/utilities
SUBROUTINE_PATH[0] (realpath) = /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib/mill
SUBROUTINE_PATH[1] (realpath) = /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib/utilities
Now type or copy : sudo python setup.py c
Add a c (clear) at the end
You should have a result similar to this if you already executed it :
fernand@debian:~/NativeCAM$ sudo python setup.py c
[sudo] password for fernand:
wait, processing...
removed link to ncam.py from /usr/lib/pymodules/python2.7/gladevcp
"from ncam import NCam" removed from /usr/share/pyshared/gladevcp/hal_pythonplugin.py
removed link to ncam.py from /usr/share/pyshared/gladevcp
glade-widget-class named NCam removed from /usr/share/glade3/catalogs/hal_python.xml
glade-widget-class-ref name NCam removed from /usr/share/glade3/catalogs/hal_python.xml
/usr/share/glade3/catalogs/hal_python.xml saved
WITHOUT a c at the end
wait, processing...
created link to ncam.py in /usr/lib/pymodules/python2.7/gladevcp
"from ncam import NCam" added to /usr/share/pyshared/gladevcp/hal_pythonplugin.py
created link to ncam.py in /usr/share/pyshared/gladevcp
glade-widget-class named NCam added to /usr/share/glade3/catalogs/hal_python.xml
glade-widget-class-ref named NCam added to /usr/share/glade3/catalogs/hal_python.xml
Now type or copy : linuxcnc configs/sim/axis/ncam_demo/mill.ini
fernand@debian:~/NativeCAM$ linuxcnc configs/sim/axis/ncam_demo/mill.ini
LINUXCNC - 2.7.8
Machine configuration directory is '/home/fernand/NativeCAM/configs/sim/axis/ncam_demo'
Machine configuration file is 'mill.ini'
Starting LinuxCNC...
Found file(REL): ./core_sim.hal
Found file(REL): ./sim_spindle_encoder.hal
Found file(REL): ./axis_manualtoolchange.hal
Found file(REL): ./simulated_home.hal
task: main loop took 0.014381 seconds
task: main loop took 0.014113 seconds
NativeCAM info:
program = /usr/lib/pymodules/python2.7/gladevcp/ncam.py
Updated 0 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/catalogs
Updated 0 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/cfg
Updated 0 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib
Updated 0 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/graphics
Updated 0 files in /home/fernand/NativeCAM/configs/sim/axis/ncam_demo/ncam/xml
task: main loop took 0.016372 seconds
task: main loop took 0.013368 seconds
Xlib.protocol.request.QueryExtension
task: main loop took 0.013335 seconds
All this has been done on Debian Wheezy with a fresh cloning of NativeCAM
Replace all *.hal files with the one from your working config directory
If you do not have this kind of result, show me the result you have. I can NOT help you without it
Regards
Fern
Last edit: 9 years 11 months ago by FernV.
9 years 11 months ago #83205 by gmouer
FernV wrote: I want you to do this :
  2. type : ./ncam.py
NativeCAM info:
inifile = NA
program = ./ncam.py
Regards
Fern
Hi Fern,
I will do a individual post for each section of your instructions along with my results to avoid confusion. I started by clearing out my old NativeCAM install and starting with a fresh clone from github.
Results of first instruction:
bridgeport@Bridgeport:~$ cd NativeCAM
bridgeport@Bridgeport:~/NativeCAM$ ./ncam.py
NativeCAM info:
inifile = NA
SYS_DIR = /home/bridgeport/NativeCAM
NCAM_DIR = /home/bridgeport/NativeCAM
program = ./ncam.py
real path = /home/bridgeport/NativeCAM/ncam.py
This appears to be the same as what you posted. I should also note that the NativeCAM standalone program launched and came up in a window.
Next instruction/results to follow.
George
9 years 11 months ago #83206 by gmouer
    NativeCAM info:
    program = ./ncam.py
    Regards
    Fern
Hi Fern,
Here is the next instruction you gave. It also opened a standalone NativeCAM window just like before.
bridgeport@Bridgeport:~/NativeCAM$ ./ncam.py -iconfigs/sim/axis/ncam_demo/mill.ini
NativeCAM info:
inifile = /home/bridgeport/NativeCAM/configs/sim/axis/ncam_demo/mill.ini
NCAM_DIR = /home/bridgeport/NativeCAM/configs/sim/axis/ncam_demo/ncam
program = ./ncam.py
Created 3 files in /home/bridgeport/NativeCAM/configs/sim/axis/ncam_demo/ncam/catalogs
Created 69 files in /home/bridgeport/NativeCAM/configs/sim/axis/ncam_demo/ncam/cfg
Created 69 files in /home/bridgeport/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib
Created 151 files in /home/bridgeport/NativeCAM/configs/sim/axis/ncam_demo/ncam/graphics
Created 5 files in /home/bridgeport/NativeCAM/configs/sim/axis/ncam_demo/ncam/xml
SUBROUTINE_PATH[0] (realpath) = /home/bridgeport/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib/mill
SUBROUTINE_PATH[1] (realpath) = /home/bridgeport/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib/utilities
On to your next instruction which I will post shortly.
George
9 years 11 months ago #83207 by gmouer
    wait, processing...
    Regards
    Fern
This time I got different results.
bridgeport@Bridgeport:~/NativeCAM$ sudo python setup.py c
[sudo] password for bridgeport:
wait, processing...
I think I know why. I started with a fresh clone from github after uninstalling the previous. Since the new clone I have NOT run setup.py, I only did exactly what you listed. Because setup.py was not run, the files are not present to be removed. Am I correct?
I resisted the temptation to run setup.py until you confirm this for me. Things are going well so far and I don't want to mess things up.
George
9 years 11 months ago #83209 by FernV
Hi George
So far it looks good (except I should have setup.py print a message when nothing needed to be cleared)
Continue now with the next step : sudo python setup.py
THE RESULT OF THIS IS CRUCIAL AND IT IS WHERE A PROBLEM MIGHT BE.
By the way, what is your Linux distribution and version ?
Fern
9 years 11 months ago #83210 by gmouer
Hi Fern,
I am running Debian Wheezy, installed off the current live CD. I then updated to master and brought everything up to date. The current version of Master on my machine is 2.8.0-pre1-2761-g2b678aa.
I shutdown the shop for the night and will continue with your instructions in the morning. Your help is much appreciated.
By the way, running the sim is only for the purposes of verifying the install, I never plan on actually using the sim. I have a working hal/ini file for the bridgeport mill and that is where I intend to implement NativeCAM. I am extremely excited about the usefulness of NativeCAM on the mill for everyday tasks.
I will post results of the next steps in the morning.
Thanks again,
George (USA, South Carolina)
Time to create page: 0.108 seconds
