NativeCAM is Features renamed
8 years 11 months ago - 8 years 11 months ago #101733 by vmihalca
Hi Fern,
I've just updated, and although in the about dialog it says 0.1.11, I see the old buttons, where a thread represents each operation.
While I had previous version, I tried to change some routines so that I can fix some bugs, so in the ncam/catalogs/lathe I have created a menu-custom.xml. Right now it seems is taking the values from this one.
Now if I delete that file, it's being recreated with the previous values each time I start linuxcnc.
I've ended up copying the values inside menu.xml into custom-menu.xml and now I can see your updates in the UI.
Any idea how can I get rid of that custom-menu.xml? :)
Last edit: 8 years 11 months ago by vmihalca.
8 years 11 months ago #101734 by FernV
Replied by FernV on topic NativeCAM is Features renamed
vmihalca wrote: ... although in the about dialog it says 0.1.11, I see the old buttons, where a thread represents each operation. Do I have to uninstall/cleanup something?
Are you using a menu-custom.xml ? If so delete it to use the standard menu.
For testing, I recommend you use the lcnc wizard and make a new copy of the files like 2.7.axis-1
This way you will be able to use the new default_template and the new tool table. Loading lcnc with the wizard and axis had some issues on my pc, I recommend you load in a terminal like $ linuxcnc lathe-mm.ini
gmoccapy did not have this problem nor gscreen
Fern
8 years 11 months ago #101735 by FernV
vmihalca wrote: ...Any idea how can I get rid of that custom-menu.xml?
Is your my-stuff sub-directory empty ?
Fern
8 years 11 months ago #101736 by vmihalca
I have only a readme file
8 years 11 months ago - 8 years 11 months ago #101738 by FernV
Erase ncam sub-directory completely, copy lathe.tbl from package (or github) in you ini directory and restart lcnc
Fern
Last edit: 8 years 11 months ago by FernV.
8 years 11 months ago #101741 by vmihalca
Hi Fern,
I have noticed that the nativecam outputs G40 and G49. Due to this, even if I do correctly my tool touch off, when the program starts, it does not account for tool length. How can I remove these lines other than saving to a file then editing that file?
Time to create page: 0.180 seconds
