NativeCAM is Features renamed
9 years 1 month ago - 9 years 1 month ago #99424 by FernV
Replied by FernV on topic NativeCAM is Features renamed
Looks like you have NOT installed the deb package.
Delete directory /home/linuxcnc/NewNativeCam completely and any references to the old non-deb setup you have. DO NOT CHECK OUT ANYMORE FROM GITHUB UNLESS YOU WANT TO DO TRANSLATION
Install with instructions you have here : forum.linuxcnc.org/40-subroutines-and-ng...age-now?limitstart=0
then run $ 'ncam -c lathe -i /home/linuxcnc/linuxcnc/configs/test_setup/test_setup.ini'
$ 'ncam -h' will show help
WARNING : lathe code is not completed and has not been tested cause my lathe is not completely converted yet
Fern
Last edit: 9 years 1 month ago by FernV.
9 years 1 month ago #99427 by vmihalca
Thanks for your quick reply.
I did installed as you suggested and now when I open linuxcnc I get two dialogs with the following messages.
Error creating link : /usr/share/linuxcnc/aux_gladevcp/NativeCAM/examples/mill -> /home/linuxcnc/linuxcnc/configs/test_setup/ncam/catalogs/mill/projects/examples
Code : [Errno 17] File exists
Error creating link : /usr/share/linuxcnc/aux_gladevcp/NativeCAM/examples/plasma -> /home/linuxcnc/linuxcnc/configs/test_setup/ncam/catalogs/plasma/projects/examples
Once I close these, linuxcnc starts successfully but there is no side window with nativecam.
I'm I missing something ?
9 years 1 month ago #99435 by FernV
Some files were not deleted. You should have a sub-directory named 'ncam' in your inifile directory. Make sure it is completely deleted.
Since some files exist, ncam aborted and was not loaded. Do not re-install NativeCAM,
just enter $ 'ncam -c lathe -i /home/linuxcnc/linuxcnc/configs/test_setup/test_setup.ini' OR the path to the inifile you want and do NOT enter 'sudo' it must be done with user rights only.
Fern
The following user(s) said Thank You: vmihalca
9 years 1 month ago - 9 years 1 month ago #99526 by vmihalca
Hi Fern,
Thanks for the previous responses! :)
I've deleted the ncam subdirectory in the inifile directory and then I ran:
linuxcnc@linuxcnc:~/linuxcnc/configs/test_setup$ ncam -i test_setup.ini -t -c lathe
NativeCAM info:
inifile = /home/linuxcnc/linuxcnc/configs/test_setup/test_setup.ini
NCAM_DIR = /home/linuxcnc/linuxcnc/configs/test_setup/ncam
SYS_DIR = /usr/share/linuxcnc/aux_gladevcp/NativeCAM
program = /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py
[RS274NGC]SUBROUTINE_PATH = ncam/my-stuff:ncam/lib/lathe:ncam/lib/utilities
Real paths:
/home/linuxcnc/linuxcnc/configs/test_setup/ncam/my-stuff
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/lathe
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/utilities
Using default lathe/menu.xml, no lathe/menu-custom.xml found
/usr/bin/ncam:2442: GtkWarning: IA__gtk_accel_label_set_accel_closure: assertion `gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
mi = _action.create_menu_item()
Previous work not saved as current work
It completed without errors and it opened the stand alone native cam.
I've closed the stand alone native cam, then opened linuxcnc, it started successfully but there's no native cam tab.
What can I do so that I see the nativecam embedded into linuxcnc?
Thanks for your previous responses! :)
Last edit: 9 years 1 month ago by vmihalca. Reason: Added more details
9 years 1 month ago #99527 by FernV
Have you started linuxcnc with this command ?
$ linuxcnc /home/linuxcnc/linuxcnc/configs/test_setup/test_setup.ini
or specify a relative path for the inifile
Fern
9 years 1 month ago #99530 by vmihalca
I have started it by clicking the link I had on the desktop. I thought that's using the updated ini file.
I'll run it as you said and let you know! :)
Thanks for your support!
