NativeCAM is Features renamed
9 years 1 month ago #98896 by proess
Nativecam newbie question
I installed Nativecam 2.8 mill-mm with linuxcnc 2.7.11.
Simulation mode works very fine. Nativecam is a great piece of software!
I 've a little stepper driven milling machine and I tried to config a custom hal (parport address, pin numbers for step and dir, pin numbers for limit switches ...) with stepconfig wizard as I 've done for the earlier linuxcnc version without nativecam. But this failed. Transferring the old custom hal file to a newer one is not easy for a newbie as the file structures have slightly changed.
Is there a possibility to use stepconfig wizard for Nativecam 2.8 mill-mm with linuxcnc 2.7.11 ?
Peter
9 years 1 month ago #98897 by chrisfairbrother
Hi, I am sure Nick had a tapered hole feature in his features. There is a config file in the NativeCAM/cfg/mill called taper-hole.cfg. Has this not been implemented into the main menu yet? Using NativeCAM 0.1.7
9 years 1 month ago #98904 by FernV
Replied by FernV on topic NativeCAM is Features renamed
chrisfairbrother wrote: Hi, I am sure Nick had a tapered hole feature in his features. There is a config file in the NativeCAM/cfg/mill called taper-hole.cfg. Has this not been implemented into the main menu yet?
taper.ngc has not been updated for a year and will not work with other sub-routines at this time. Though I used it myself months ago, I had to select sub-routines I thought more usefull when working to make it deb based.
It is on my todo list for later.
Regards
Fern
9 years 1 month ago #98905 by FernV
proess wrote: ...Is there a possibility to use stepconfig wizard for Nativecam 2.8 mill-mm with linuxcnc 2.7.11 ?
Hi Peter,
I am sorry I can not help you with stepconfig wizard.
Work on your setup and make sure everything is OK without NativeCAM. It is easy to add after.
Regards
Fern
9 years 1 month ago #98916 by proess
Hi all
thanks for the quick reply. I will do as suggested.
Peter
9 years 1 month ago #98961 by ericson
hi Fern, will nativecam work with gscreen in the future?
Time to create page: 0.382 seconds
