NativeCAM is Features renamed
8 years 11 months ago #102424 by vmihalca
Thanks for the updates! I'll be off until next week but I can't wait to test it! :)
8 years 11 months ago #102431 by BigDo
Replied by BigDo on topic NativeCAM is Features renamed
Hi Fern,
i have tested it after sudo apt-get update and the bug is still there.
I am on Ubuntu 12.04 LTS RTAI.
Regards
Niko
8 years 11 months ago - 8 years 11 months ago #102434 by FernV
Replied by FernV on topic NativeCAM is Features renamed
Update to latest [strike]0.1.14a[/strike] 0.1.14b
Fern
Last edit: 8 years 11 months ago by FernV.
The following user(s) said Thank You: BigDo
8 years 10 months ago #103020 by FernV
BigDo wrote: i have tested it after sudo apt-get update and the bug is still there.
Is the problem still there with 0.1.14b ?
Fern
8 years 10 months ago #103027 by vmihalca
Hi Fern,
I've had little time to test the 14b version, but from what I've tested, it did not reproduced.
Right now I'm facing some issues with internal threading. I was trying to do an internal thread, using the values from this table: mdmetric.com/tech/M-thead%20600.htm
I tried a metric 20 with 1mm pitch, and used the major diameter, and minor diameter from the table for the nut columns.
I did the touch off correctly, and running commands from MDI, was posiyioning the tool in the expected location.
When running from nativecam, the tip of the cutter was always about 1mm towards center than where it should have been.
Basically it was doing air cuts. I've set thread peak to -1, it says it needs to be negative for internal threads...
Other than that, I can't figure it out what I'm doing wrong.
8 years 10 months ago #103050 by FernV
vmihalca wrote: I've had little time to test the 14b version, but from what I've tested, it did not reproduced.
I hope it is solved for good
...I'm facing some issues with internal threading. I was trying to do an internal thread, using the values from this table: mdmetric.com/tech/M-thead%20600.htm
This table is very interesting and lot of needed info is available.
However, the way I understand LinuxCNC, you can not use those major and minor diameter or you will end up with something like this. I guess your cutter is 60° and the point must go deep enough.
You have to use the points I show in this image.
Based on the chart for a 20X1mm the major diameter would be (20mm to 20.304mm) + ((1/8 height of the thread, H in the image, not H1 : 0.866 mm for a pitch of 1mm) * 2 for diameter). Automatic minor diameter will calculate the depth where the cutter will go.
A value of -1 mm for thread peak should be OK. All the parameters are the same as specified in lcnc documentation.
Regards
Fern
Time to create page: 0.186 seconds
