- Thank you received: 8
FernV wrote:
BigDo wrote: i have tested it after sudo apt-get update and the bug is still there.
I am on Ubuntu 12.04 LTS RTAI.
Is the problem still there with 0.1.14b ?
Fern
Hi Gene,Gene1934 wrote: ...One gotcha that recently occurred here, was that installing NativeCAM kills CamPY, and the update it put in a day or so back, did it again, requiring the CamPY_setup, basically its installer, has to be done after each NativeCAM update.
Are you talking a preview for NativeCAM ? If so you must toggle 'Block Delete'... I am not seeing a preview?
Many users like to have it in a new tab but personnaly, I prefer seeing changes immediately and installed it in axis and gmoccapy in the front page (if I can say)I have made no attempt to make it an LCNC "tab" utility because its window it bigger
