Hi Fern
thank you for explanation,
today something like that happened ->
I turned on the update of Linux today and ... after this none of my Nativecam / previously working correctly / configurations do not worm up, I also tried with the wizard and it's the same error, maybe some conflict after the update
a pop-up appears with a message about the error, pls info what can i do
Zbigi
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.11
Machine configuration directory is '/home/z/linuxcnc/configs/f4'
Machine configuration file is 'f4.ini'
INIFILE=/home/z/linuxcnc/configs/f4/f4.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./f4.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
Embeded tab command "halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x 58720396 -U --catalog=mill /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.ui" exited with error: 1
Killing task linuxcncsvr, PID=4786
Killing task milltask, PID=4815
task: 105 cycles, min=0.000008, max=0.021160, avg=0.008283, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
Note: Using POSIX non-realtime
sched_setaffinity: Invalid argument
File "/usr/bin/gladevcp", line 45, in <module>
import gladevcp.makepins
File "/usr/lib/pymodules/python2.7/gladevcp/__init__.py", line 1, in <module>
from hal_pythonplugin import *
File "/usr/lib/pymodules/python2.7/gladevcp/hal_pythonplugin.py", line 1, in <module>
from camview import CamView
ImportError: No module named camview
<commandline>:0: waitpid failed gladevcp gladevcp
<commandline>:0: gladevcp exited without becoming ready
4786
PID TTY STAT TIME COMMAND
4815
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 0000000000091400 (usable)
[ 0.000000] BIOS-e820: 0000000000091400 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000cf228000 (usable)
[ 0.000000] BIOS-e820: 00000000cf228000 - 00000000cf26c000 (reserved)
[ 0.000000] BIOS-e820: 00000000cf26c000 - 00000000cf5b7000 (usable)
[ 0.000000] BIOS-e820: 00000000cf5b7000 - 00000000cf5e7000 (reserved)
[ 0.000000] BIOS-e820: 00000000cf5e7000 - 00000000cf7e7000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cf7e7000 - 00000000cf7ff000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cf7ff000 - 00000000cf800000 (usable)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffc00000 - 00000000ffc20000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000042e000000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: Dell Inc. Precision M4600/08V9YG, BIOS A07 10/02/2011
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xcf800 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 080000000 mask FC0000000 write-back
[ 0.000000] 2 base 0C0000000 mask FF0000000 write-back
[ 0.000000] 3 base 100000000 mask F00000000 write-back
[ 0.000000] 4 base 200000000 mask E00000000 write-back
[ 0.000000] 5 base 400000000 mask FE0000000 write-back
[ 0.000000] 6 base 420000000 mask FF0000000 write-back
[ 0.000000] 7 base 42E000000 mask FFE000000 uncachable
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000d0000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00f18c0] f18c0
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c008d000] 8d000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36526000 - 3728b000
[ 0.000000] ACPI: RSDP 000fe300 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT cf7fde18 00084 (v01 DELL CBX3 06222004 MSFT 00010013)
[ 0.000000] ACPI: FACP cf787d98 000F4 (v04 DELL CBX3 06222004 MSFT 00010013)
[ 0.000000] ACPI Warning: 32/64 FACS address mismatch in FADT - two FACS tables! (20120320/tbfadt-378)
[ 0.000000] ACPI Warning: 32/64X FACS address mismatch in FADT - 0xCF7E4E40/0x00000000CF7E4D40, using 32 (20120320/tbfadt-502)
[ 0.000000] ACPI: DSDT cf754018 08A1A (v02 INT430 SYSFexxx 00001001 INTL 20090903)
[ 0.000000] ACPI: FACS cf7e4e40 00040
[ 0.000000] ACPI: APIC cf7fcf18 000CC (v02 DELL CBX3 06222004 MSFT 00010013)
[ 0.000000] ACPI: TCPA cf7e5d18 00032 (v02 00000000 00000000)
[ 0.000000] ACPI: SSDT cf788a98 002F9 (v01 DELLTP TPM 00003000 INTL 20090903)
[ 0.000000] ACPI: MCFG cf7e5c98 0003C (v01 DELL SNDYBRDG 06222004 MSFT 00000097)
[ 0.000000] ACPI: HPET cf7e5c18 00038 (v01 A M I PCHHPET 06222004 AMI. 00000003)
[ 0.000000] ACPI: BOOT cf7e5b98 00028 (v01 DELL CBX3 06222004 AMI 00010013)
[ 0.000000] ACPI: SSDT cf76b018 00990 (v01 PmRef Cpu0Ist 00003000 INTL 20090903)
[ 0.000000] ACPI: SSDT cf76a018 00996 (v01 PmRef CpuPm 00003000 INTL 20090903)
[ 0.000000] ACPI: DMAR cf7e4a18 000B0 (v01 INTEL SNB 00000001 INTL 00000001)
[ 0.000000] ACPI: SLIC cf774c18 00176 (v03 DELL CBX3 06222004 MSFT 00010013)
[ 0.000000] ACPI: SSDT cf772018 018C3 (v01 NvdRef NvdTabl 00001000 INTL 20090903)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2432MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000cf800
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x00000091
[ 0.000000] 0: 0x00000100 -> 0x000cf228
[ 0.000000] 0: 0x000cf26c -> 0x000cf5b7
[ 0.000000] 0: 0x000cf7ff -> 0x000cf800
[ 0.000000] On node 0 totalpages: 849141
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4b36200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3937 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4865 pages used for memmap
[ 0.000000] HighMem zone: 617077 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x05] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x07] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x09] lapic_id[0x08] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0a] lapic_id[0x09] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0b] lapic_id[0x0a] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0c] lapic_id[0x0b] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0d] lapic_id[0x0c] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0e] lapic_id[0x0d] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0f] lapic_id[0x0e] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x10] lapic_id[0x0f] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] 16 Processors exceeds NR_CPUS limit of 8
[ 0.000000] SMP: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 0000000000091000 - 0000000000092000
[ 0.000000] PM: Registered nosave memory: 0000000000092000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at cf800000 (gap: cf800000:2f51c000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f7763000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 842500
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=1e1bd602-e1c4-4931-b7a0-d270a24dc079 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 6799232 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000cf800)
[ 0.000000] Memory: 3342368k/3399680k available (3495k kernel code, 54196k reserved, 1237k data, 416k init, 2487768k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:744 16
[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 2195.091 MHz processor.
[ 0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 4390.18 BogoMIPS (lpj=8780364)
[ 0.000006] pid_max: default: 32768 minimum: 301
[ 0.000044] Security Framework initialized
[ 0.000048] AppArmor: AppArmor disabled by boot time parameter
[ 0.000065] Mount-cache hash table entries: 512
[ 0.000245] Initializing cgroup subsys cpuacct
[ 0.000247] Initializing cgroup subsys memory
[ 0.000255] Initializing cgroup subsys devices
[ 0.000257] Initializing cgroup subsys freezer
[ 0.000258] Initializing cgroup subsys net_cls
[ 0.000260] Initializing cgroup subsys blkio
[ 0.000266] Initializing cgroup subsys perf_event
[ 0.000292] CPU: Physical Processor ID: 0
[ 0.000294] CPU: Processor Core ID: 0
[ 0.000298] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000299] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(
[ 0.000302] mce: CPU supports 9 MCE banks
[ 0.000316] CPU0: Thermal monitoring enabled (TM1)
[ 0.000420] ACPI: Core revision 20120320
[ 0.008925] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.009336] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.048980] CPU0: Intel(R) Core(TM) i7-2720QM CPU @ 2.20GHz stepping 07
[ 0.156199] Performance Events: PEBS fmt1+, 16-deep LBR, SandyBridge events, Intel PMU driver.
[ 0.156206] PEBS disabled due to CPU errata.
[ 0.156209] ... version: 3
[ 0.156210] ... bit width: 48
[ 0.156212] ... generic registers: 4
[ 0.156214] ... value mask: 0000ffffffffffff
[ 0.156215] ... max period: 000000007fffffff
[ 0.156217] ... fixed-purpose events: 3
[ 0.156218] ... event mask: 000000070000000f
[ 0.168295] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.180210] CPU 1 irqstacks, hard=f4118000 soft=f411a000
[ 0.180215] Booting Node 0, Processors #1
[ 0.190605] Initializing CPU#1
[ 0.193364] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.200195] CPU 2 irqstacks, hard=f4148000 soft=f414a000
[ 0.200201] #2
[ 0.210509] Initializing CPU#2
[ 0.213344] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.220171] CPU 3 irqstacks, hard=f415c000 soft=f415e000
[ 0.220177] #3
[ 0.230485] Initializing CPU#3
[ 0.233318] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.240148] CPU 4 irqstacks, hard=f416e000 soft=f4170000
[ 0.240153] #4
[ 0.250561] Initializing CPU#4
[ 0.253300] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.260127] CPU 5 irqstacks, hard=f41a0000 soft=f41a2000
[ 0.260133] #5
[ 0.270440] Initializing CPU#5
[ 0.273275] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.280102] CPU 6 irqstacks, hard=f41b4000 soft=f41b6000
[ 0.280107] #6
[ 0.290316] Initializing CPU#6
[ 0.293150] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.300080] CPU 7 irqstacks, hard=f41c4000 soft=f41c6000
[ 0.300085] #7 Ok.
[ 0.310393] Initializing CPU#7
[ 0.313225] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.313258] Brought up 8 CPUs
[ 0.313261] Total of 8 processors activated (35121.45 BogoMIPS).
[ 0.320207] devtmpfs: initialized
[ 0.320440] PM: Registering ACPI NVS region [mem 0xcf5e7000-0xcf7e6fff] (2097152 bytes)
[ 0.320610] dummy:
[ 0.320674] NET: Registered protocol family 16
[ 0.320791] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.320793] ACPI: bus type pci registered
[ 0.320859] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.320862] PCI: not using MMCONFIG
[ 0.321076] PCI: PCI BIOS revision 2.10 entry at 0xfce72, last bus=18
[ 0.321078] PCI: Using configuration type 1 for base access
[ 0.321088] dmi type 0xB1 record - unknown flag
[ 0.321816] bio: create slab <bio-0> at 0
[ 0.321921] ACPI: Added _OSI(Module Device)
[ 0.321924] ACPI: Added _OSI(Processor Device)
[ 0.321926] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.321928] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.324252] ACPI: EC: Look up EC in DSDT
[ 0.331879] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.338415] ACPI: SSDT cf5d7798 00727 (v01 PmRef Cpu0Cst 00003001 INTL 20090903)
[ 0.339039] ACPI: Dynamic OEM Table Load:
[ 0.339042] ACPI: SSDT (null) 00727 (v01 PmRef Cpu0Cst 00003001 INTL 20090903)
[ 0.339418] ACPI: SSDT cf5d8a98 00303 (v01 PmRef ApIst 00003000 INTL 20090903)
[ 0.340104] ACPI: Dynamic OEM Table Load:
[ 0.340108] ACPI: SSDT (null) 00303 (v01 PmRef ApIst 00003000 INTL 20090903)
[ 0.340272] ACPI: SSDT cf5d6d98 00119 (v01 PmRef ApCst 00003000 INTL 20090903)
[ 0.340886] ACPI: Dynamic OEM Table Load:
[ 0.340890] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20090903)
[ 0.343998] ACPI: Interpreter enabled
[ 0.344006] ACPI: (supports S0 S3 S4 S5)
[ 0.344035] ACPI: Using IOAPIC for interrupt routing
[ 0.344057] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.344381] ACPI Error: Invalid/unsupported resource descriptor: Type 0x00 (20120320/utresrc-650)
[ 0.344687] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in ACPI motherboard resources
[ 0.344689] PCI: Using MMCONFIG for extended config space
[ 0.358074] ACPI: EC: GPE = 0x10, I/O: command/status = 0x934, data = 0x930
[ 0.358803] ACPI: No dock devices found.
[ 0.358809] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.359273] \_SB_.PCI0:_OSC invalid UUID
[ 0.359275] _OSC request data:1 8 0
[ 0.359281] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.360078] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.360081] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.360084] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.360087] pci_root PNP0A08:00: host bridge window [mem 0xd0000000-0xfeafffff]
[ 0.360090] pci_root PNP0A08:00: host bridge window [mem 0xfed40000-0xfed44fff]
[ 0.360124] PCI host bridge to bus 0000:00
[ 0.360126] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.360129] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.360131] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.360134] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfeafffff]
[ 0.360136] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed44fff]
[ 0.360146] pci 0000:00:00.0: [8086:0104] type 00 class 0x060000
[ 0.360187] pci 0000:00:01.0: [8086:0101] type 01 class 0x060400
[ 0.360218] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.360271] pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
[ 0.360299] pci 0000:00:16.0: reg 10: [mem 0xe1eb0000-0xe1eb000f 64bit]
[ 0.360367] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.360398] pci 0000:00:16.3: [8086:1c3d] type 00 class 0x070002
[ 0.360419] pci 0000:00:16.3: reg 10: [io 0x80a0-0x80a7]
[ 0.360431] pci 0000:00:16.3: reg 14: [mem 0xe1e90000-0xe1e90fff]
[ 0.360526] pci 0000:00:19.0: [8086:1502] type 00 class 0x020000
[ 0.360548] pci 0000:00:19.0: reg 10: [mem 0xe1e00000-0xe1e1ffff]
[ 0.360558] pci 0000:00:19.0: reg 14: [mem 0xe1e80000-0xe1e80fff]
[ 0.360568] pci 0000:00:19.0: reg 18: [io 0x8040-0x805f]
[ 0.360625] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.360655] pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
[ 0.360679] pci 0000:00:1a.0: reg 10: [mem 0xe1e70000-0xe1e703ff]
[ 0.360760] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.360790] pci 0000:00:1b.0: [8086:1c20] type 00 class 0x040300
[ 0.360808] pci 0000:00:1b.0: reg 10: [mem 0xe1e60000-0xe1e63fff 64bit]
[ 0.360871] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.360898] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
[ 0.360969] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.360997] pci 0000:00:1c.1: [8086:1c12] type 01 class 0x060400
[ 0.361068] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.361098] pci 0000:00:1c.2: [8086:1c14] type 01 class 0x060400
[ 0.361173] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.361203] pci 0000:00:1c.3: [8086:1c16] type 01 class 0x060400
[ 0.361275] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.361310] pci 0000:00:1c.7: [8086:1c1e] type 01 class 0x060400
[ 0.361385] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold
[ 0.361419] pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
[ 0.361443] pci 0000:00:1d.0: reg 10: [mem 0xe1e50000-0xe1e503ff]
[ 0.361525] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.361554] pci 0000:00:1f.0: [8086:1c4f] type 00 class 0x060100
[ 0.361682] pci 0000:00:1f.2: [8086:282a] type 00 class 0x010400
[ 0.361704] pci 0000:00:1f.2: reg 10: [io 0x8090-0x8097]
[ 0.361714] pci 0000:00:1f.2: reg 14: [io 0x8080-0x8083]
[ 0.361723] pci 0000:00:1f.2: reg 18: [io 0x8070-0x8077]
[ 0.361733] pci 0000:00:1f.2: reg 1c: [io 0x8060-0x8063]
[ 0.361742] pci 0000:00:1f.2: reg 20: [io 0x8020-0x803f]
[ 0.361752] pci 0000:00:1f.2: reg 24: [mem 0xe1e40000-0xe1e407ff]
[ 0.361791] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.361814] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
[ 0.361832] pci 0000:00:1f.3: reg 10: [mem 0xe1e30000-0xe1e300ff 64bit]
[ 0.361856] pci 0000:00:1f.3: reg 20: [io 0x8000-0x801f]
[ 0.361922] pci 0000:01:00.0: [10de:0dda] type 00 class 0x030000
[ 0.361932] pci 0000:01:00.0: reg 10: [mem 0xde000000-0xdfffffff]
[ 0.361943] pci 0000:01:00.0: reg 14: [mem 0xd0000000-0xd7ffffff 64bit pref]
[ 0.361954] pci 0000:01:00.0: reg 1c: [mem 0xd8000000-0xdbffffff 64bit pref]
[ 0.361961] pci 0000:01:00.0: reg 24: [io 0x7000-0x707f]
[ 0.361969] pci 0000:01:00.0: reg 30: [mem 0xe0000000-0xe007ffff pref]
[ 0.362011] pci 0000:01:00.1: [10de:0be9] type 00 class 0x040300
[ 0.362021] pci 0000:01:00.1: reg 10: [mem 0xe0080000-0xe0083fff]
[ 0.367991] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.368000] pci 0000:00:01.0: bridge window [io 0x7000-0x7fff]
[ 0.368009] pci 0000:00:01.0: bridge window [mem 0xde000000-0xe00fffff]
[ 0.368021] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdbffffff 64bit pref]
[ 0.368086] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.368184] pci 0000:03:00.0: [8086:422b] type 00 class 0x028000
[ 0.368232] pci 0000:03:00.0: reg 10: [mem 0xe1d00000-0xe1d01fff 64bit]
[ 0.368411] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.375989] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.376005] pci 0000:00:1c.1: bridge window [mem 0xe1d00000-0xe1dfffff]
[ 0.376078] pci 0000:00:1c.2: PCI bridge to [bus 04-09]
[ 0.376082] pci 0000:00:1c.2: bridge window [io 0x6000-0x6fff]
[ 0.376087] pci 0000:00:1c.2: bridge window [mem 0xe1200000-0xe1bfffff]
[ 0.376095] pci 0000:00:1c.2: bridge window [mem 0xdd200000-0xddbfffff 64bit pref]
[ 0.376193] pci 0000:0a:00.0: [1033:0194] type 00 class 0x0c0330
[ 0.376242] pci 0000:0a:00.0: reg 10: [mem 0xe1c00000-0xe1c01fff 64bit]
[ 0.376408] pci 0000:0a:00.0: PME# supported from D0 D3hot D3cold
[ 0.383980] pci 0000:00:1c.3: PCI bridge to [bus 0a-0a]
[ 0.383996] pci 0000:00:1c.3: bridge window [mem 0xe1c00000-0xe1cfffff]
[ 0.384112] pci 0000:0b:00.0: [1217:11f7] type 00 class 0x0c0010
[ 0.384148] pci 0000:0b:00.0: reg 10: [mem 0xe0130000-0xe0130fff]
[ 0.384359] pci 0000:0b:00.0: supports D1 D2
[ 0.384361] pci 0000:0b:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.384451] pci 0000:0b:00.1: [1217:8320] type 00 class 0x080501
[ 0.384481] pci 0000:0b:00.1: reg 10: [mem 0xe0120000-0xe01201ff]
[ 0.384685] pci 0000:0b:00.1: supports D1 D2
[ 0.384687] pci 0000:0b:00.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.384770] pci 0000:0b:00.2: [1217:8330] type 00 class 0x018000
[ 0.384806] pci 0000:0b:00.2: reg 10: [mem 0xe0110000-0xe01103ff]
[ 0.384855] pci 0000:0b:00.2: reg 18: [mem 0xe0100000-0xe01003ff]
[ 0.385019] pci 0000:0b:00.2: supports D1 D2
[ 0.385021] pci 0000:0b:00.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.391999] pci 0000:00:1c.7: PCI bridge to [bus 0b-12]
[ 0.392015] pci 0000:00:1c.7: bridge window [io 0x2000-0x5fff]
[ 0.392020] pci 0000:00:1c.7: bridge window [mem 0xe0100000-0xe11fffff]
[ 0.392027] pci 0000:00:1c.7: bridge window [mem 0xdc100000-0xdd1fffff 64bit pref]
[ 0.392057] pci_bus 0000:00: on NUMA node 0
[ 0.392061] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.392376] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.392431] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.392486] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.392539] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
[ 0.392601] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP08._PRT]
[ 0.392652] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[ 0.392781] \_SB_.PCI0:_OSC invalid UUID
[ 0.392783] _OSC request data:1 f 0
[ 0.392788] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.399172] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.399235] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.399295] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.399355] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.399414] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 *5 6 7 10 12 14 15)
[ 0.399474] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
[ 0.399534] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 *3 4 5 6 7 10 12 14 15)
[ 0.399592] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
[ 0.399680] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.399685] vgaarb: loaded
[ 0.399687] vgaarb: bridge control possible 0000:01:00.0
[ 0.399715] PCI: Using ACPI for IRQ routing
[ 0.400578] PCI: pci_cache_line_size set to 64 bytes
[ 0.400709] reserve RAM buffer: 0000000000091400 - 000000000009ffff
[ 0.400712] reserve RAM buffer: 00000000cf228000 - 00000000cfffffff
[ 0.400714] reserve RAM buffer: 00000000cf5b7000 - 00000000cfffffff
[ 0.400717] reserve RAM buffer: 00000000cf800000 - 00000000cfffffff
[ 0.400841] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.400850] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.403869] Switching to clocksource hpet
[ 0.403957] pnp: PnP ACPI init
[ 0.403967] ACPI: bus type pnp registered
[ 0.404393] pnp 00:00: [bus 00-3e]
[ 0.404396] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.404398] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.404400] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.404403] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.404405] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.404408] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.404410] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.404412] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.404415] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.404417] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.404419] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.404421] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.404424] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.404426] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.404428] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.404431] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.404433] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.404435] pnp 00:00: [mem 0xd0000000-0xfeafffff window]
[ 0.404438] pnp 00:00: [mem 0xfed40000-0xfed44fff window]
[ 0.404489] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.404505] pnp 00:01: [io 0x0000-0x001f]
[ 0.404507] pnp 00:01: [io 0x0081-0x0091]
[ 0.404509] pnp 00:01: [io 0x0093-0x009f]
[ 0.404511] pnp 00:01: [io 0x00c0-0x00df]
[ 0.404514] pnp 00:01: [dma 4]
[ 0.404536] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.404546] pnp 00:02: [mem 0xff000000-0xffffffff]
[ 0.404567] pnp 00:02: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.404648] pnp 00:03: [mem 0xfed00000-0xfed003ff]
[ 0.404688] system 00:03: [mem 0xfed00000-0xfed003ff] has been reserved
[ 0.404691] system 00:03: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active)
[ 0.404703] pnp 00:04: [io 0x00f0]
[ 0.404711] pnp 00:04: [irq 13]
[ 0.404736] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.404748] pnp 00:05: [io 0x002e-0x002f]
[ 0.404750] pnp 00:05: [io 0x004e-0x004f]
[ 0.404752] pnp 00:05: [io 0x0061]
[ 0.404754] pnp 00:05: [io 0x0063]
[ 0.404756] pnp 00:05: [io 0x0065]
[ 0.404758] pnp 00:05: [io 0x0067]
[ 0.404761] pnp 00:05: [io 0x0070]
[ 0.404763] pnp 00:05: [io 0x0080]
[ 0.404765] pnp 00:05: [io 0x0092]
[ 0.404767] pnp 00:05: [io 0x00b2-0x00b3]
[ 0.404769] pnp 00:05: [io 0x0680-0x069f]
[ 0.404771] pnp 00:05: [io 0x1000-0x100f]
[ 0.404773] pnp 00:05: [io 0xffff]
[ 0.404775] pnp 00:05: [io 0xffff]
[ 0.404777] pnp 00:05: [io 0x0400-0x047f]
[ 0.404779] pnp 00:05: [io 0x0500-0x057f]
[ 0.404781] pnp 00:05: [io 0x164e-0x164f]
[ 0.404826] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.404829] system 00:05: [io 0x1000-0x100f] has been reserved
[ 0.404831] system 00:05: [io 0xffff] has been reserved
[ 0.404834] system 00:05: [io 0xffff] has been reserved
[ 0.404836] system 00:05: [io 0x0400-0x047f] has been reserved
[ 0.404839] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.404841] system 00:05: [io 0x164e-0x164f] has been reserved
[ 0.404844] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.404854] pnp 00:06: [io 0x0070-0x0077]
[ 0.404860] pnp 00:06: [irq 8]
[ 0.404882] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.404893] pnp 00:07: [io 0x0060]
[ 0.404895] pnp 00:07: [io 0x0064]
[ 0.404900] pnp 00:07: [irq 1]
[ 0.404924] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.406076] pnp 00:08: Plug and Play ACPI device, IDs PNP0401 (disabled)
[ 0.406092] pnp 00:09: [irq 12]
[ 0.406118] pnp 00:09: Plug and Play ACPI device, IDs DLL04a3 PNP0f13 (active)
[ 0.406377] pnp 00:0a: [mem 0xfed1c000-0xfed1ffff]
[ 0.406380] pnp 00:0a: [mem 0xfed10000-0xfed17fff]
[ 0.406382] pnp 00:0a: [mem 0xfed18000-0xfed18fff]
[ 0.406384] pnp 00:0a: [mem 0xfed19000-0xfed19fff]
[ 0.406386] pnp 00:0a: [mem 0xf8000000-0xfbffffff]
[ 0.406389] pnp 00:0a: [mem 0xfed20000-0xfed3ffff]
[ 0.406391] pnp 00:0a: [mem 0xfed90000-0xfed93fff]
[ 0.406393] pnp 00:0a: [mem 0xfed45000-0xfed8ffff]
[ 0.406395] pnp 00:0a: [mem 0xff000000-0xffffffff]
[ 0.406397] pnp 00:0a: [mem 0xfee00000-0xfeefffff]
[ 0.406399] pnp 00:0a: [mem 0x00000000-0xffffffff disabled]
[ 0.406402] pnp 00:0a: [mem 0x00000000-0xffffffff disabled]
[ 0.406468] system 00:0a: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.406471] system 00:0a: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.406474] system 00:0a: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.406477] system 00:0a: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.406480] system 00:0a: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.406483] system 00:0a: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.406485] system 00:0a: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.406488] system 00:0a: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.406491] system 00:0a: [mem 0xff000000-0xffffffff] could not be reserved
[ 0.406494] system 00:0a: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.406497] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.406587] pnp 00:0b: [irq 23]
[ 0.406631] pnp 00:0b: Plug and Play ACPI device, IDs SMO8800 (active)
[ 0.408606] ACPI Error: Invalid/unsupported resource descriptor: Type 0x00 (20120320/utresrc-650)
[ 0.408612] pnp 00:0c: can't evaluate _CRS: 12311
[ 0.408754] system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.408826] pnp: PnP ACPI: found 13 devices
[ 0.408828] ACPI: ACPI bus type pnp unregistered
[ 0.408831] PnPBIOS: Disabled by ACPI PNP
[ 0.445646] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.445650] pci 0000:00:01.0: bridge window [io 0x7000-0x7fff]
[ 0.445654] pci 0000:00:01.0: bridge window [mem 0xde000000-0xe00fffff]
[ 0.445657] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdbffffff 64bit pref]
[ 0.445662] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.445677] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.445684] pci 0000:00:1c.1: bridge window [mem 0xe1d00000-0xe1dfffff]
[ 0.445694] pci 0000:00:1c.2: PCI bridge to [bus 04-09]
[ 0.445698] pci 0000:00:1c.2: bridge window [io 0x6000-0x6fff]
[ 0.445704] pci 0000:00:1c.2: bridge window [mem 0xe1200000-0xe1bfffff]
[ 0.445710] pci 0000:00:1c.2: bridge window [mem 0xdd200000-0xddbfffff 64bit pref]
[ 0.445718] pci 0000:00:1c.3: PCI bridge to [bus 0a-0a]
[ 0.445724] pci 0000:00:1c.3: bridge window [mem 0xe1c00000-0xe1cfffff]
[ 0.445735] pci 0000:00:1c.7: PCI bridge to [bus 0b-12]
[ 0.445738] pci 0000:00:1c.7: bridge window [io 0x2000-0x5fff]
[ 0.445745] pci 0000:00:1c.7: bridge window [mem 0xe0100000-0xe11fffff]
[ 0.445750] pci 0000:00:1c.7: bridge window [mem 0xdc100000-0xdd1fffff 64bit pref]
[ 0.445819] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.445821] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.445823] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.445826] pci_bus 0000:00: resource 7 [mem 0xd0000000-0xfeafffff]
[ 0.445828] pci_bus 0000:00: resource 8 [mem 0xfed40000-0xfed44fff]
[ 0.445830] pci_bus 0000:01: resource 0 [io 0x7000-0x7fff]
[ 0.445833] pci_bus 0000:01: resource 1 [mem 0xde000000-0xe00fffff]
[ 0.445835] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdbffffff 64bit pref]
[ 0.445838] pci_bus 0000:03: resource 1 [mem 0xe1d00000-0xe1dfffff]
[ 0.445840] pci_bus 0000:04: resource 0 [io 0x6000-0x6fff]
[ 0.445842] pci_bus 0000:04: resource 1 [mem 0xe1200000-0xe1bfffff]
[ 0.445845] pci_bus 0000:04: resource 2 [mem 0xdd200000-0xddbfffff 64bit pref]
[ 0.445847] pci_bus 0000:0a: resource 1 [mem 0xe1c00000-0xe1cfffff]
[ 0.445849] pci_bus 0000:0b: resource 0 [io 0x2000-0x5fff]
[ 0.445852] pci_bus 0000:0b: resource 1 [mem 0xe0100000-0xe11fffff]
[ 0.445854] pci_bus 0000:0b: resource 2 [mem 0xdc100000-0xdd1fffff 64bit pref]
[ 0.445972] NET: Registered protocol family 2
[ 0.446034] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.446228] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.446448] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.446544] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.446547] TCP: reno registered
[ 0.446549] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.446554] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.446653] NET: Registered protocol family 1
[ 0.446753] pci 0000:01:00.0: Boot video device
[ 0.446829] PCI: CLS 64 bytes, default 64
[ 0.446865] Unpacking initramfs...
[ 0.735288] Freeing initrd memory: 13716k freed
[ 0.737173] Simple Boot Flag at 0xf3 set to 0x1
[ 0.737906] audit: initializing netlink socket (disabled)
[ 0.737923] type=2000 audit(1515786252.628:1): initialized
[ 0.750968] highmem bounce pool size: 64 pages
[ 0.750973] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.751253] VFS: Disk quotas dquot_6.5.2
[ 0.751288] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.751364] msgmni has been set to 1695
[ 0.751548] alg: No test for stdrng (krng)
[ 0.751591] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.751595] io scheduler noop registered
[ 0.751597] io scheduler deadline registered
[ 0.751635] io scheduler cfq registered (default)
[ 0.751999] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.752017] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.752019] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.752504] GHES: HEST is not enabled!
[ 0.752516] isapnp: Scanning for PnP cards...
[ 1.107257] isapnp: No Plug & Play device found
[ 1.107303] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.127892] 0000:00:16.3: ttyS0 at I/O 0x80a0 (irq = 17) is a 16550A
[ 1.128080] Linux agpgart interface v0.103
[ 1.128344] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.128788] i8042: Warning: Keylock active
[ 1.129975] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.130000] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.130102] mousedev: PS/2 mouse device common for all mice
[ 1.130142] rtc_cmos 00:06: RTC can wake from S4
[ 1.130303] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 1.130333] rtc0: alarms up to one year, y3k, 242 bytes nvram, hpet irqs
[ 1.130470] TCP: cubic registered
[ 1.130566] NET: Registered protocol family 10
[ 1.130835] Mobile IPv6
[ 1.130838] NET: Registered protocol family 17
[ 1.130842] Registering the dns_resolver key type
[ 1.130885] Using IPI No-Shortcut mode
[ 1.130948] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.131114] PM: Hibernation image not present or could not be loaded.
[ 1.131123] registered taskstats version 1
[ 1.131888] rtc_cmos 00:06: setting system clock to 2018-01-12 19:44:13 UTC (1515786253)
[ 1.132001] Freeing unused kernel memory: 416k freed
[ 1.132130] Write protecting the kernel text: 3496k
[ 1.132157] Write protecting the kernel read-only data: 984k
[ 1.145696] udevd[75]: starting version 175
[ 1.158030] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 1.158034] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 1.158087] e1000e 0000:00:19.0: setting latency timer to 64
[ 1.158178] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.159589] usbcore: registered new interface driver usbfs
[ 1.159617] usbcore: registered new interface driver hub
[ 1.159883] usbcore: registered new device driver usb
[ 1.160232] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.172398] sdhci: Secure Digital Host Controller Interface driver
[ 1.172402] sdhci: Copyright(c) Pierre Ossman
[ 1.173011] sdhci-pci 0000:0b:00.1: SDHCI controller found [1217:8320] (rev 5)
[ 1.173101] sdhci-pci 0000:0b:00.1: Invalid iomem size. You may experience problems.
[ 1.173255] mmc0: no vmmc regulator found
[ 1.173303] Registered led device: mmc0::
[ 1.173683] SCSI subsystem initialized
[ 1.174344] mmc0: SDHCI controller on PCI [0000:0b:00.1] using DMA
[ 1.175516] microcode: CPU0 sig=0x206a7, pf=0x10, revision=0x1b
[ 1.175520] xhci_hcd 0000:0a:00.0: xHCI Host Controller
[ 1.175552] xhci_hcd 0000:0a:00.0: new USB bus registered, assigned bus number 1
[ 1.175843] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.175848] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.175852] usb usb1: Product: xHCI Host Controller
[ 1.175855] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.175858] usb usb1: SerialNumber: 0000:0a:00.0
[ 1.175922] libata version 3.00 loaded.
[ 1.175986] xHCI xhci_add_endpoint called for root hub
[ 1.175990] xHCI xhci_check_bandwidth called for root hub
[ 1.176040] hub 1-0:1.0: USB hub found
[ 1.176051] hub 1-0:1.0: 2 ports detected
[ 1.176153] xhci_hcd 0000:0a:00.0: xHCI Host Controller
[ 1.176163] xhci_hcd 0000:0a:00.0: new USB bus registered, assigned bus number 2
[ 1.179161] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.179164] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.179167] usb usb2: Product: xHCI Host Controller
[ 1.179169] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.179171] usb usb2: SerialNumber: 0000:0a:00.0
[ 1.179275] xHCI xhci_add_endpoint called for root hub
[ 1.179279] xHCI xhci_check_bandwidth called for root hub
[ 1.179325] hub 2-0:1.0: USB hub found
[ 1.179338] hub 2-0:1.0: 2 ports detected
[ 1.187212] microcode: CPU0 updated to revision 0x29, date = 2013-06-12
[ 1.187266] microcode: CPU1 sig=0x206a7, pf=0x10, revision=0x1b
[ 1.189682] microcode: CPU1 updated to revision 0x29, date = 2013-06-12
[ 1.189695] microcode: CPU2 sig=0x206a7, pf=0x10, revision=0x1b
[ 1.192058] microcode: CPU2 updated to revision 0x29, date = 2013-06-12
[ 1.192070] microcode: CPU3 sig=0x206a7, pf=0x10, revision=0x1b
[ 1.194316] microcode: CPU3 updated to revision 0x29, date = 2013-06-12
[ 1.194328] microcode: CPU4 sig=0x206a7, pf=0x10, revision=0x1b
[ 1.196676] microcode: CPU4 updated to revision 0x29, date = 2013-06-12
[ 1.196691] microcode: CPU5 sig=0x206a7, pf=0x10, revision=0x1b
[ 1.198952] microcode: CPU5 updated to revision 0x29, date = 2013-06-12
[ 1.198964] microcode: CPU6 sig=0x206a7, pf=0x10, revision=0x1b
[ 1.201328] microcode: CPU6 updated to revision 0x29, date = 2013-06-12
[ 1.201339] microcode: CPU7 sig=0x206a7, pf=0x10, revision=0x1b
[ 1.203654] microcode: CPU7 updated to revision 0x29, date = 2013-06-12
[ 1.203702] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.231102] firewire_ohci 0000:0b:00.0: added OHCI v1.10 device as card 0, 8 IR + 8 IT contexts, quirks 0x10
[ 1.404073] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) d0:67:e5:3c:25:80
[ 1.404077] e1000e 0000:00:19.0: eth0: Intel(R) PRO/1000 Network Connection
[ 1.404111] e1000e 0000:00:19.0: eth0: MAC: 10, PHY: 11, PBA No: 0041FF-0FF
[ 1.404175] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.404182] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.404195] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 1.404228] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.408117] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 1.408124] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xe1e70000
[ 1.418794] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.418842] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.418845] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.418847] usb usb3: Product: EHCI Host Controller
[ 1.418850] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.418852] usb usb3: SerialNumber: 0000:00:1a.0
[ 1.418979] hub 3-0:1.0: USB hub found
[ 1.418985] hub 3-0:1.0: 3 ports detected
[ 1.419099] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.419102] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.419109] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 1.419132] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.423019] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.423038] ehci_hcd 0000:00:1d.0: irq 17, io mem 0xe1e50000
[ 1.434776] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.434821] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.434824] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.434826] usb usb4: Product: EHCI Host Controller
[ 1.434828] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.434830] usb usb4: SerialNumber: 0000:00:1d.0
[ 1.434943] hub 4-0:1.0: USB hub found
[ 1.434950] hub 4-0:1.0: 3 ports detected
[ 1.435056] ahci 0000:00:1f.2: version 3.0
[ 1.435117] ahci: SSS flag set, parallel bus scan disabled
[ 1.450804] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x39 impl RAID mode
[ 1.450808] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio slum part ems sxs apst
[ 1.450815] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.475271] scsi0 : ahci
[ 1.475412] scsi1 : ahci
[ 1.475486] scsi2 : ahci
[ 1.475561] scsi3 : ahci
[ 1.475635] scsi4 : ahci
[ 1.475711] scsi5 : ahci
[ 1.476243] ata1: SATA max UDMA/133 abar m2048@0xe1e40000 port 0xe1e40100 irq 18
[ 1.476245] ata2: DUMMY
[ 1.476247] ata3: DUMMY
[ 1.476250] ata4: SATA max UDMA/133 abar m2048@0xe1e40000 port 0xe1e40280 irq 18
[ 1.476254] ata5: SATA max UDMA/133 abar m2048@0xe1e40000 port 0xe1e40300 irq 18
[ 1.476258] ata6: SATA max UDMA/133 abar m2048@0xe1e40000 port 0xe1e40380 irq 18
[ 1.634559] usb 1-1: new low-speed USB device number 2 using xhci_hcd
[ 1.680637] usb 1-1: New USB device found, idVendor=2635, idProduct=0601
[ 1.680646] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.680653] usb 1-1: Product: 2.4G RF MOUSE
[ 1.680747] usb 1-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.730453] firewire_core 0000:0b:00.0: giving up on Config ROM for node id ffc0
[ 1.734450] Refined TSC clocksource calibration: 2195.012 MHz.
[ 1.734463] Switching to clocksource tsc
[ 1.794366] usb 3-1: new high-speed USB device number 2 using ehci_hcd
[ 1.794376] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.817191] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1.817433] ata1.00: ATA-8: ST9500423AS, 0002DEM1, max UDMA/133
[ 1.817441] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.860277] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1.860513] ata1.00: configured for UDMA/133
[ 1.860652] scsi 0:0:0:0: Direct-Access ATA ST9500423AS 0002 PQ: 0 ANSI: 5
[ 1.926622] usb 3-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.926630] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.926884] hub 3-1:1.0: USB hub found
[ 1.926976] hub 3-1:1.0: 6 ports detected
[ 1.978268] firewire_core 0000:0b:00.0: created device fw0: GUID 02a29701314fc000, S400
[ 2.038106] usb 4-1: new high-speed USB device number 2 using ehci_hcd
[ 2.170344] usb 4-1: New USB device found, idVendor=8087, idProduct=0024
[ 2.170352] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.170608] hub 4-1:1.0: USB hub found
[ 2.170701] hub 4-1:1.0: 8 ports detected
[ 2.177956] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.182337] ata4.00: ATAPI: HL-DT-ST DVD+/-RW GS30N, A101, max UDMA/133
[ 2.187451] ata4.00: configured for UDMA/133
[ 2.192918] scsi 3:0:0:0: CD-ROM HL-DT-ST DVD+-RW GS30N A101 PQ: 0 ANSI: 5
[ 2.242029] usb 3-1.4: new full-speed USB device number 3 using ehci_hcd
[ 2.338163] usb 3-1.4: New USB device found, idVendor=413c, idProduct=8187
[ 2.338171] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.338178] usb 3-1.4: Product: DW375 Bluetooth Module
[ 2.338184] usb 3-1.4: Manufacturer: Dell Computer Corp
[ 2.338189] usb 3-1.4: SerialNumber: 60D819FAC46F
[ 2.409846] usb 3-1.5: new high-speed USB device number 4 using ehci_hcd
[ 2.509098] usb 3-1.5: New USB device found, idVendor=05ca, idProduct=181e
[ 2.509107] usb 3-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.509114] usb 3-1.5: Product: Laptop_Integrated_Webcam_FHD
[ 2.509120] usb 3-1.5: Manufacturer: CN0CJ3P27248719QC6L4A00
[ 2.509596] ata5: SATA link down (SStatus 0 SControl 300)
[ 2.581647] usb 4-1.2: new high-speed USB device number 3 using ehci_hcd
[ 2.768182] usb 4-1.2: New USB device found, idVendor=041e, idProduct=4095
[ 2.768190] usb 4-1.2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.768197] usb 4-1.2: Product: Live! Cam Sync HD VF0770
[ 2.768203] usb 4-1.2: Manufacturer: Creative Technology Ltd.
[ 2.768208] usb 4-1.2: SerialNumber: 2017062858525
[ 2.829235] ata6: SATA link down (SStatus 0 SControl 300)
[ 2.832683] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.832687] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.832766] sd 0:0:0:0: [sda] Write Protect is off
[ 2.832770] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.832801] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.842532] input: 2.4G RF MOUSE as /devices/pci0000:00/0000:00:1c.3/0000:0a:00.0/usb1/1-1/1-1:1.0/input/input1
[ 2.842613] generic-usb 0003:2635:0601.0001: input,hidraw0: USB HID v1.11 Mouse [ 2.4G RF MOUSE] on usb-0000:0a:00.0-1/input0
[ 2.842632] usbcore: registered new interface driver usbhid
[ 2.842634] usbhid: USB HID core driver
[ 2.845361] usb 4-1.8: new full-speed USB device number 4 using ehci_hcd
[ 2.879982] sda: sda1 sda2 < sda5 >
[ 2.880331] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.881923] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.881983] sr 3:0:0:0: Attached scsi generic sg1 type 5
[ 2.886078] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda caddy
[ 2.886082] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.886250] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 2.959733] usb 4-1.8: New USB device found, idVendor=0a5c, idProduct=5801
[ 2.959743] usb 4-1.8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.959751] usb 4-1.8: Product: 5880
[ 2.959756] usb 4-1.8: Manufacturer: Broadcom Corp
[ 2.959761] usb 4-1.8: SerialNumber: 0123456789ABCD
[ 2.959846] usb 4-1.8: config 0 descriptor??
[ 3.288778] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 4.599326] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 5.909872] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 7.220464] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 8.232785] PM: Starting manual resume from disk
[ 8.232788] PM: Hibernation image partition 8:5 present
[ 8.232790] PM: Looking for hibernation image.
[ 8.233103] PM: Image not found (code -22)
[ 8.233105] PM: Hibernation image not present or could not be loaded.
[ 8.309270] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.531015] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 9.841588] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 10.285852] udevd[428]: starting version 175
[ 10.625529] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
[ 10.625971] ACPI: Lid Switch [LID]
[ 10.626027] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 10.626032] ACPI: Power Button [PBTN]
[ 10.626077] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4
[ 10.626081] ACPI: Sleep Button [SBTN]
[ 10.626127] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 10.626131] ACPI: Power Button [PWRF]
[ 10.642736] wmi: Mapper loaded
[ 10.857879] ACPI: AC Adapter [AC] (on-line)
[ 11.079758] ACPI: Battery Slot [BAT0] (battery present)
[ 11.091355] ACPI Warning: 0x00008000-0x0000801f SystemIO conflicts with Region \_SB_.PCI0.SBUS.SMBI 1 (20120320/utaddress-251)
[ 11.091363] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 11.152143] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 11.153124] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 11.167226] parport_pc 00:08: [io 0x0378-0x037b]
[ 11.167312] parport_pc 00:08: [irq 5]
[ 11.169598] parport_pc 00:08: activated
[ 11.169602] parport_pc 00:08: reported by Plug and Play ACPI
[ 11.169701] parport_pc 00:08: disabled
[ 11.327248] input: Dell WMI hotkeys as /devices/virtual/input/input6
[ 11.344127] iTCO_vendor_support: vendor-support=0
[ 11.344151] cfg80211: Calling CRDA to update world regulatory domain
[ 11.402310] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 11.402383] iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[ 11.402449] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 11.421365] acpi device:2b: registered as cooling_device0
[ 11.421977] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:28/LNXVIDEO:00/input/input7
[ 11.422023] ACPI: Video Device [VID] (multi-head: yes rom: yes post: no)
[ 11.471778] Bluetooth: Core ver 2.16
[ 11.471800] NET: Registered protocol family 31
[ 11.471803] Bluetooth: HCI device and connection manager initialized
[ 11.471806] Bluetooth: HCI socket layer initialized
[ 11.471809] Bluetooth: L2CAP socket layer initialized
[ 11.471815] Bluetooth: SCO socket layer initialized
[ 11.590772] usbcore: registered new interface driver btusb
[ 11.596531] [drm] Initialized drm 1.1.0 20060810
[ 11.736859] Intel(R) Wireless WiFi Link AGN driver for Linux, in-tree:
[ 11.736862] Copyright(c) 2003-2012 Intel Corporation
[ 11.736936] iwlwifi 0000:03:00.0: pci_resource_len = 0x00002000
[ 11.736938] iwlwifi 0000:03:00.0: pci_resource_base = f81a8000
[ 11.736941] iwlwifi 0000:03:00.0: HW Revision ID = 0x35
[ 11.736946] iwlwifi 0000:03:00.0: pci_enable_msi failed(0Xffffffff)
[ 11.911958] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input8
[ 11.921350] input: HDA Intel PCH Dock Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 11.921425] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 11.921490] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 11.921552] input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 11.921745] hda_intel: Disabling MSI
[ 12.409330] input: DualPoint Stick as /devices/platform/i8042/serio1/input/input13
[ 12.421995] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input14
[ 12.462698] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 12.866305] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[ 12.866388] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[ 12.866457] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[ 12.866523] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[ 12.866947] nouveau 0000:01:00.0: power state changed by ACPI to D0
[ 12.866958] nouveau 0000:01:00.0: power state changed by ACPI to D0
[ 12.867176] [drm] nouveau 0000:01:00.0: Detected an NVc0 generation card (0x0c3d00a1)
[ 12.874779] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS
[ 12.880998] iwlwifi 0000:03:00.0: loaded firmware version 9.221.4.1 build 25532
[ 12.881173] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUG disabled
[ 12.881176] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUGFS disabled
[ 12.881178] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEVICE_TRACING disabled
[ 12.881180] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEVICE_TESTMODE disabled
[ 12.881182] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_P2P disabled
[ 12.881184] iwlwifi 0000:03:00.0: Detected Intel(R) Centrino(R) Ultimate-N 6300 AGN, REV=0x74
[ 12.881218] iwlwifi 0000:03:00.0: L1 Enabled; Disabling L0S
[ 12.894495] iwlwifi 0000:03:00.0: device EEPROM VER=0x43a, CALIB=0x6
[ 12.894500] iwlwifi 0000:03:00.0: Device SKU: 0x1F0
[ 12.894504] iwlwifi 0000:03:00.0: Valid Tx ant: 0x7, Valid Rx ant: 0x7
[ 12.894528] iwlwifi 0000:03:00.0: Tunable channels: 13 802.11bg, 24 802.11a channels
[ 12.894648] Registered led device: phy0-led
[ 12.967098] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 12.967101] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN
[ 12.967104] [drm] nouveau 0000:01:00.0: BIT BIOS found
[ 12.967107] [drm] nouveau 0000:01:00.0: Bios version 70.06.36.00
[ 12.967111] [drm] nouveau 0000:01:00.0: TMDS table version 2.0
[ 12.967352] [drm] nouveau 0000:01:00.0: MXM: BIOS version 3.0
[ 12.969851] [drm] nouveau 0000:01:00.0: MXM: MXMS Version 3.0
[ 12.969859] [drm] nouveau 0000:01:00.0: DCB version 4.0
[ 12.969862] [drm] nouveau 0000:01:00.0: DCB outp 00: 01000313 00010034
[ 12.969865] [drm] nouveau 0000:01:00.0: DCB outp 03: 080153d6 0f220020
[ 12.969867] [drm] nouveau 0000:01:00.0: DCB outp 04: 08015392 00020020
[ 12.969869] [drm] nouveau 0000:01:00.0: DCB outp 05: 080143c6 0f220010
[ 12.969872] [drm] nouveau 0000:01:00.0: DCB outp 06: 08014382 00020010
[ 12.969874] [drm] nouveau 0000:01:00.0: DCB outp 08: 040383b6 0f230014
[ 12.969876] [drm] nouveau 0000:01:00.0: DCB outp 10: 020273a6 0f220010
[ 12.969878] [drm] nouveau 0000:01:00.0: DCB outp 11: 02027362 00020010
[ 12.969880] [drm] nouveau 0000:01:00.0: DCB outp 13: 02049300 00000000
[ 12.969882] [drm] nouveau 0000:01:00.0: DCB conn 00: 00000040
[ 12.969885] [drm] nouveau 0000:01:00.0: DCB conn 01: 00001161
[ 12.969888] [drm] nouveau 0000:01:00.0: DCB conn 02: 00001231
[ 12.969890] [drm] nouveau 0000:01:00.0: DCB conn 03: 01000331
[ 12.969893] [drm] nouveau 0000:01:00.0: DCB conn 04: 01000446
[ 12.969895] [drm] nouveau 0000:01:00.0: DCB conn 05: 02000546
[ 12.969898] [drm] nouveau 0000:01:00.0: DCB conn 06: 00010631
[ 12.969900] [drm] nouveau 0000:01:00.0: DCB conn 07: 00010746
[ 12.969903] [drm] nouveau 0000:01:00.0: DCB conn 08: 00020847
[ 12.969905] [drm] nouveau 0000:01:00.0: DCB conn 09: 00000900
[ 12.969910] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0x8143
[ 12.999784] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0x8837
[ 13.005366] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 13.006800] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0x9B55
[ 13.006803] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0x9B5F
[ 13.006861] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0x9D34
[ 13.006863] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table at offset 0x9D99
[ 13.020501] Linux media interface: v0.10
[ 13.026060] Linux video capture interface: v2.00
[ 13.026691] [drm] nouveau 0000:01:00.0: 0x9D99: Condition still not met after 20ms, skipping following opcodes
[ 13.031102] [TTM] Zone kernel: Available graphics memory: 434366 kiB
[ 13.031105] [TTM] Zone highmem: Available graphics memory: 1678250 kiB
[ 13.031107] [TTM] Initializing pool allocator
[ 13.031118] [drm] nouveau 0000:01:00.0: Detected 2048MiB VRAM (DDR3)
[ 13.036513] [drm] nouveau 0000:01:00.0: 512 MiB GART (aperture)
[ 13.042433] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 13.042435] [drm] No driver support for vblank timestamp query.
[ 13.042438] [drm] nouveau 0000:01:00.0: ACPI backlight interface available, not registering our own
[ 13.047890] [drm] nouveau 0000:01:00.0: 2 available performance level(s)
[ 13.047893] [drm] nouveau 0000:01:00.0: 0: core 50MHz shader 101MHz memory 132MHz
[ 13.047896] [drm] nouveau 0000:01:00.0: 1: core 202MHz shader 405MHz memory 324MHz
[ 13.047900] [drm] nouveau 0000:01:00.0: c: core 202MHz shader 405MHz memory 324MHz voltage 890mV
[ 13.055515] uvcvideo: Found UVC 1.00 device Laptop_Integrated_Webcam_FHD (05ca:181e)
[ 13.057668] input: Laptop_Integrated_Webcam_FHD as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.5/3-1.5:1.0/input/input19
[ 13.057759] uvcvideo: Found UVC 1.00 device Live! Cam Sync HD VF0770 (041e:4095)
[ 13.069049] input: Live! Cam Sync HD VF0770 as /devices/pci0000:00/0000:00:1d.0/usb4/4-1/4-1.2/4-1.2:1.0/input/input20
[ 13.069135] usbcore: registered new interface driver uvcvideo
[ 13.069138] USB Video Class driver (1.1.1)
[ 13.101066] cfg80211: World regulatory domain updated:
[ 13.101070] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 13.101073] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 13.101075] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 13.101077] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 13.101080] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 13.101082] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 13.101084] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 13.101086] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 13.101089] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 13.265892] usbcore: registered new interface driver snd-usb-audio
[ 13.773204] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 14.738950] [drm] nouveau 0000:01:00.0: allocated 1920x1080 fb: 0x1c0000, bo f3b05200
[ 14.739014] fbcon: nouveaufb (fb0) is primary device
[ 15.013100] Console: switching to colour frame buffer device 240x67
[ 15.018210] fb0: nouveaufb frame buffer device
[ 15.018212] drm: registered panic notifier
[ 15.018217] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0
[ 15.083817] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 15.994146] Adding 19786748k swap on /dev/sda5. Priority:-1 extents:1 across:19786748k
[ 16.005861] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 16.234412] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 16.354043] loop: module loaded
[ 16.394378] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 17.602073] RPC: Registered named UNIX socket transport module.
[ 17.602076] RPC: Registered udp transport module.
[ 17.602078] RPC: Registered tcp transport module.
[ 17.602079] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 17.704933] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 17.742345] FS-Cache: Loaded
[ 17.778263] NFS: Registering the id_resolver key type
[ 17.778282] FS-Cache: Netfs 'nfs' registered for caching
[ 17.783100] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 19.015496] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 19.846843] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input21
[ 20.291149] Bluetooth: RFCOMM TTY layer initialized
[ 20.291156] Bluetooth: RFCOMM socket layer initialized
[ 20.291158] Bluetooth: RFCOMM ver 1.11
[ 20.326057] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 20.561558] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.561561] Bluetooth: BNEP filters: protocol multicast
[ 21.636615] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 21.658180] lp: driver loaded but no devices found
[ 21.940047] ppdev: user-space parallel port driver
[ 22.766923] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 22.769426] iwlwifi 0000:03:00.0: L1 Enabled; Disabling L0S
[ 22.769613] iwlwifi 0000:03:00.0: Radio type=0x0-0x3-0x1
[ 22.943178] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 23.010224] iwlwifi 0000:03:00.0: L1 Enabled; Disabling L0S
[ 23.010412] iwlwifi 0000:03:00.0: Radio type=0x0-0x3-0x1
[ 23.128823] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 24.253676] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 25.564293] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 26.398951] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 26.399051] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 26.874856] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 28.185363] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 29.495972] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 29.633353] wlan0: authenticate with ac:84:c9:2d:5b:77
[ 29.669075] wlan0: send auth to ac:84:c9:2d:5b:77 (try 1/3)
[ 29.871489] wlan0: send auth to ac:84:c9:2d:5b:77 (try 2/3)
[ 29.872343] wlan0: authenticated
[ 29.875554] wlan0: associate with ac:84:c9:2d:5b:77 (try 1/3)
[ 29.878350] wlan0: RX AssocResp from ac:84:c9:2d:5b:77 (capab=0x511 status=0 aid=23)
[ 29.884115] wlan0: associated
[ 29.884203] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 29.884256] cfg80211: Calling CRDA for country: PL
[ 29.887886] cfg80211: Regulatory domain changed to country: PL
[ 29.887889] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 29.887892] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 29.887894] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 29.887897] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 29.887899] cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm)
[ 29.887901] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 30.806536] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 32.117094] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 33.427650] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 34.738209] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 36.048774] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 36.751923] eth0: no IPv6 routers present
[ 37.359326] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 38.669882] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 39.980447] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 40.739541] wlan0: no IPv6 routers present
[ 41.291006] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 42.601561] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 43.912120] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 45.386499] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 46.533242] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 47.843787] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 49.154359] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 50.464920] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 51.775475] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 53.086025] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 54.396597] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 55.707155] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 57.017718] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 58.324279] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 59.634835] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 60.945396] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 62.255955] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 63.566514] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 64.877075] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 66.187623] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 67.498182] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 68.808752] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 70.119300] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 71.429881] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 72.740429] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 74.050978] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 75.478428] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 76.672107] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 77.982667] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 79.293230] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 80.603785] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 81.914345] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 83.224906] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 84.535463] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 85.846026] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 87.156582] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 88.463147] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 89.773704] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 91.084254] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 92.394826] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 93.705373] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 95.015946] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 96.370457] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 97.637063] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 98.947621] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 100.258181] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 101.568738] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 102.879297] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 104.189859] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 105.500407] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 106.810978] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 108.121539] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 109.432096] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 110.742654] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 112.053205] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 113.363776] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 114.674321] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 115.984879] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 117.295441] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 118.602003] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 119.912577] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 121.223126] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 122.533691] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 123.844253] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 125.154813] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 126.465357] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 127.775930] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 129.086488] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 130.397050] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 131.707607] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 133.018170] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 134.328727] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 135.639286] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 136.949846] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 138.260406] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 139.570964] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 140.881525] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 142.192088] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 143.502589] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 144.813209] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 146.123718] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 147.434327] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 148.744888] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 150.051450] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 151.362023] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 151.568603] [drm] nouveau 0000:01:00.0: PMFB0_SUBP0: 0x037f0040
[ 151.568610] [drm] nouveau 0000:01:00.0: PMFB0_SUBP1: 0x037f0040
[ 151.568615] [drm] nouveau 0000:01:00.0: PMFB1_SUBP0: 0x037f0040
[ 151.568620] [drm] nouveau 0000:01:00.0: PMFB1_SUBP1: 0x037f0040
[ 152.672570] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 153.983081] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 155.293635] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 156.604201] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 157.914764] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 159.225320] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 160.535927] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 161.846464] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 163.157043] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 164.467605] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 165.778162] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 167.249550] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 168.399279] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 169.709839] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 171.020402] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 172.330959] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 173.641520] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 174.952081] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 176.262636] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 177.573195] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 178.883720] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 180.194314] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 181.500873] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 182.811433] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 184.121996] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 185.432551] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 186.743115] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 188.141574] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 189.364230] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 190.674789] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 191.985337] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 193.295915] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 194.606472] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 195.917026] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 197.227588] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 198.538100] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 199.848708] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 201.159264] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 202.469824] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 203.780383] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 205.090943] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 206.401502] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 207.712060] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 209.022621] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 210.333183] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 211.643742] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 212.954300] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 214.264865] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 216.881982] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 218.233504] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 219.503102] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 220.813655] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 222.124205] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 223.434776] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 224.745332] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 226.055896] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 227.366404] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 228.676971] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 229.987574] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 231.298135] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 232.608692] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 233.919255] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 235.229815] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 236.540374] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 237.850931] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 239.161503] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 240.472037] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 243.093169] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 244.403726] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 245.710289] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 248.331408] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 249.641967] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 250.952524] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 252.263083] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 253.573642] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 254.884205] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 256.194762] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 257.505311] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 258.815880] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 260.126443] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 261.437002] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 262.747557] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 264.058118] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 265.368680] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 266.679238] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 267.989797] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 269.300357] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 270.610915] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 271.921463] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 273.232035] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 274.542596] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 275.853150] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 277.159715] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 278.470267] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 279.912695] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 281.091393] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 282.401954] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 283.712517] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 285.023075] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 286.333631] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 287.644196] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 288.954753] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 291.575871] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 292.886427] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 294.196987] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 295.507546] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 296.818107] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 298.128666] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 299.439230] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 300.749771] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 302.060331] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 303.370902] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 304.681466] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 305.992020] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 307.302570] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 308.609143] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 310.004651] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 311.230265] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 312.540820] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 313.851386] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 315.161943] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 316.472489] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 317.783058] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 320.404178] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 321.714740] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 324.335858] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 325.646416] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 326.956976] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 329.578095] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 330.896645] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 332.199214] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 333.509761] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 334.820332] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 336.130890] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 337.441451] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 340.062571] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 341.369131] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 342.679689] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 345.300809] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 346.611365] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 349.232489] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 350.543048] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 351.853605] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 354.474725] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 355.785284] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 357.095842] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 358.406405] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 359.716962] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 361.027506] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 362.338069] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 363.648638] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 364.959199] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 366.269756] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 367.580260] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 368.890877] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 371.683808] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 372.818558] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 374.129123] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 375.439688] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 378.060797] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 379.371358] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 380.681913] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 381.992476] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 383.303037] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 384.613593] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 385.924151] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 387.234713] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 388.545274] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 389.855831] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 391.166390] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 392.476949] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 395.098072] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 396.408627] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 397.719183] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 399.029748] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 400.340304] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 402.961423] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 404.271930] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 405.582589] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 406.889104] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 408.199701] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 409.510217] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 412.131344] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 413.441902] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 418.684110] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 419.994703] firewire_core 0000:0b:00.0: rediscovered device fw0
[ 422.667726] firewire_core 0000:0b:00.0: rediscovered device fw0
