- Thank you received: 3
kjacobs wrote: ...when using polylines for a feature that has an axis symmetry and is slightly more complex, the idea is of course to just draw one half and then use the mirror function with zero offset to complete the feature. When I do that, the polyline is in two parts and will also be milled in two separate milling actions, irrespective of closing or not closing the original polyline. I was expecting that the final result of the mirroring with zero offset would be a single (closed) polyline. Am I doing something wrong or is that by design? I attached an example of a cutout for a D-Sub 25 pin connector.
Apart from that, I finished a new translation to german using the 0.14b version and will send that to you after some more testing. And thanks again for your wonderful work!
Gene1934 wrote: from what you say that it complains about not finding the o-word sub I am guessing that you try to use the ngc file on a lcnc system that does not have NativeCAM installed?
Yes, it is. I generated the ngc file from that xml file using ncam on that machine.
Because that won't work, as it will be missing what is in SUBROUTINE_PATH = ncam/my-stuff:ncam/lib/mill:ncam/lib/utilities:macros, which has to be part of your ini-file.
And that is not in my ini-file's SUBROUTINE_PATH statement. If it exists, I'll add it.
Yes, and no, I did find the ~/nativecam/my-stuff directory but it only has a README in it, nothing else. I'll see if I can find the original dl. Didn't find that, but did find what looks to be the originally unpacked in directory. And a bunch of subs exist there, which I'll move to my nc_files/subs directory. The first one, angle.ngc, gave mc kittens like I didn't own it, but a separate ls -l says I do, investigating. It copied it as opposed to moving it.
That fixed that error, but now its looking for poly-add-item in line 163. I'll see if theres an install script in there someplace and re-run it. Doesn't exist! Obviously my install is AFU. locate does not find the .tgz or .xz I'll chase back up the thread and get the link again.
