Hi
I just received my PPV2 USB stick a couple of days ago and today set about installing. Eventually it will be for my lathe, but in the first instance I am following the mill guidelines to allow me to confirm I can get a working setup.
I've been following the guide, but have come across a strange problem - the config_file.txt does not seem to exist/get created.
If I choose a config, I then get an error that the machine cannot be connected to. The PC then shuts down and when I restart, there is no config_file.txt
I've also tried creating an empty file, named config_file.txt that contains one line of ~/tmc/configs/tormach_mill/mill_pp.ini
However when I boot the PC it just boots into an empty screen with the backdrop showing and PP does not start. I've tried a couple of times now and same result every time/
Any help would be much appreciated
