setting up for Parallel port Tutoral Part 3
10 years 2 months ago #79247 by gmouer
I have a spare 5i25/7i77 for a mill retro that I will start before too long. I could use that 5i25 I suppose to "get me in". I realize it will reflash the 5i25 but I'm pretty sure its just a matter of reflashing it back to 7i77 software.
Right now, I just want to get into pathpilot and surf around a bit on a familiarization tour. I'm helping a newcomer to lcnc get a lathe up under pathpilot and I just might use it for that mill retro I will be doing. Its tough to help someone without being able to have the software running in front of you and the guy I am helping is far away.
10 years 2 months ago - 10 years 2 months ago #79262 by cncbasher
yes i know , i help many all around the world , but nice to have a working machine at the end , it amazes people , that i can control say a machine in new zealand from here in the UK .
be carefull that you know what software is flashed in the 5i25 to start with , and dont connect the 7i77
follow my tutorials re flashing different bit files , it can send you on a wild chase , if the config files have any error at all
i'd personally put a newcomer on lcnc , and after a learning time swap a hard drive to pathpilot , it's not as easy to fight not only pathpilot
but to not know lcnc , only makes the matter worse in my opinion .
Last edit: 10 years 2 months ago by cncbasher.
10 years 2 months ago #79286 by smgvbest
this may be a dumb question but why not use /tmc/configs/tormach_lathe/tormach_lathe_sim.ini for the config.
in my config_file.txt I have
~/tmc/configs/tormach_lathe/tormach_lathe_sim.ini
I've run sim mode without issue
but also
in operator_login find this line
# uncomment next line to force sim mode
#GREPCOUNT="1"
unccomment GREPCOUNT="1" and is says it will run sim mode.
I haven't tried that one since I call /tormach_lathe_sim.ini directly
am I missing something, seems to work fine to me
10 years 2 months ago #79390 by gmouer
My goal is just to look around lathe a bit, and later mill also. The PC I have does not have a parallel port. I could use a 5i25 but would rather not risk it just to look around PP. I have no intentions of attempting to use it to operate a machine at this point, just look it over and get familiar with it.
Will a lathe Parallel port config launch ok on a machine without a parallel port?
I think the answer is a stripped down hal and ini file with neither hostmot or the parallel port driver and probably some lines commented out so pathpilot will launch.
George
10 years 2 months ago #79391 by smgvbest
Thats why I say
edit /home/operator/config_file.txt and put in
That for me puts in into sim mode
I've not had a single problem running in sim mode on my pathpilot
gmouer wrote: My goal is just to look around lathe a bit, and later mill also. The PC I have does not have a parallel port. I could use a 5i25 but would rather not risk it just to look around PP. I have no intentions of attempting to use it to operate a machine at this point, just look it over and get familiar with it.
George
10 years 2 months ago #79400 by gmouer
That would cover the INI file but what about a HAL file? Its within the HAL file where the interface hardware would be loaded and the cause of a error if neither a parallel port nor mesa board are present.
Every software I have seen thus far requires either a parallel port or a 5i25.
Time to create page: 0.649 seconds
