setting up for Parallel port Tutoral Part 3
10 years 2 months ago #79487 by gmouer
Ok, now I go it !! Sounds like my objective is doable without much fuss at all.
10 years 2 months ago - 10 years 2 months ago #79488 by gmouer
cncbasher wrote: if the bios has a lpt port listed , although a parallel port socket is not fitted , then it will work
or fit a pci printer port card is an option
so long as it thinks a printer port exists then it will work .
that goes for lcnc as well as pathpilot .
Which begs the question...
Smgvbest, does your computer have a lpt port listed in its bios screens? I realize there is no physical port.
Last edit: 10 years 2 months ago by gmouer.
10 years 2 months ago #79494 by racedirector
You can run LCNC on a virtual machine in sim mode so PP should be the same. Going to confirm tomorrow by setting up 1.9.6 under VirtualBox on my Mac
10 years 2 months ago #79496 by cncbasher
you may have problems running in a virtual machine , due to the realtime that pathpilot uses
and to the increased Latency that it produces . this goes the same for lcnc , apart from the more recent uspace variant .
10 years 2 months ago #79498 by smgvbest
It does have one listed in the bios and it is disabled in the bios
But my config is not setup to use a parallel port nor a mesa card. I'm running the simulator mode of PP/LinuxCNC
The following user(s) said Thank You: gmouer
10 years 2 months ago #79580 by dinkata
cncbasher wrote: if you have problems or need help , feel welcome to shout .
also any amendments i'm happy to add .
i hope i have covered the main points clearly enough for you to follow .
Thank you, this works .How do I add " charge pump " ?
is it possible add ClassicLadder in PathPilot ?
Best regards .
Dinyo
Time to create page: 0.461 seconds
