setting up for Parallel port Tutoral Part 3
10 years 5 months ago #74941 by cncbasher
tko829:
you can use any linuxcnc compatable pc , that is all you need . theirs nothing special required
unless you wish to use a Mesa pci Interface ( 5i25) or 5i25 & 7i76 addon ,
10 years 2 months ago #79215 by gmouer
The outlined procedure is for a mill using the parallel port.
Is there a suggested procedure for a lathe?
George
10 years 2 months ago #79222 by tommylight
I think it is the same, except replace whatever refers to mill with lathe, and it should work.
I do not use Path Pilot, so do not take my word for it.
10 years 2 months ago - 10 years 2 months ago #79236 by cncbasher
George ,
what is it that you need ? , and i'll sort it , is it a lathe pp config you need ? or the procedure for modifying the gui files
i have config files for a pp lathe , i'll post them shortly , once iv'e confirmed the gui changes , i'll post a part 4 to concern a lathe
in a day or so , but if you want any details in the meantime then message me or email .
Sarah
Last edit: 10 years 2 months ago by cncbasher.
10 years 2 months ago #79237 by gmouer
Thanks much Sarah ! I can wait for you to post them here, that way all can benefit. The procedures already posted, and files, are for mill and the differences for lathe were not clear to me.
I'm curious, is there a method to run in simulation mode? Without a PP or mesa? Some just want to poke around pathpilot a bit and are not go further.
Thanks again,
George
10 years 2 months ago #79238 by cncbasher
it's not that easy to set up without a mesa card , but once the mods are done , to create a parallel port , then you do have essentialy a sim setup . pathpilot has many checks for certian procedures or order , and will throw you a curve ball , and kick you out the stadium lol .
i'll see if i can get most of this done today
Time to create page: 0.527 seconds
