setting up for Parallel port Tutoral Part 3
10 years 2 months ago - 10 years 2 months ago #79448 by smgvbest
The big item missing from the tormach_lathe_sim.ini fie is they do not load the BITFILE0
[HOSTMOT2] # **** This is for info only **** # DRIVER0=hm2_pci # BOARD0=5i25 BITFILE0=mesa/tormach_lathe.bit
but you look at the tormach_lathe_sim.ini file you'll also see it includes the sim hal files
[HAL] HALUI = halui HALFILE = tormach_lathe_sim.hal POSTGUI_SHUTTLEXPRESS_HALFILE = millshuttlexpress.hal POSTGUI_HALFILE = postgui_tormach_lathe_sim.hal
here's the diffs for the ini file and the HAL files
File Name: tormach_la...diff.txt
File Size:3.55 KB
File Size:21.17 KB
File Name: postgui_to...diff.txt
File Size:2.14 KB
Last edit: 10 years 2 months ago by smgvbest.
10 years 2 months ago #79465 by cncbasher
if you do not have a parallel port on the pc then you'll have problems ,
as the bios will not be loaded either .
you cannot run a lcnc config in pathpilot without modifying . they are similar but not identical.
10 years 2 months ago #79467 by gmouer
Oh well. Guess that rules out a old laptop for getting acquainted with PP.
10 years 2 months ago #79475 by smgvbest
The question asked was can you run PP without a pp to look at it
forget for now about a parallel port config if all you want to do is look at PP.
You can run PP in simulator mode to take a look at PP with no hardware.
The config information I supplied is a pathpilot config.
it was already in the ~/tmc/configs/tormach_lathe/ directory and supplied by tormach.
all I did was change my config_file.txt and run operator_login.sh with the sim config and pathpilot came right up for me
my Pathpilot is running fine in simulator mode. that is all I did to take a look at PP.
if you want to run PP with a non Tormach Config then you have to do magic on the files to make them work.
10 years 2 months ago #79476 by cncbasher
if the bios has a lpt port listed , although a parallel port socket is not fitted , then it will work
or fit a pci printer port card is an option
so long as it thinks a printer port exists then it will work .
that goes for lcnc as well as pathpilot .
10 years 2 months ago #79477 by smgvbest
was your reply in reply to mine or earlier post?
I'm just saying I am running in sim mode in pathpilot, no parallel port, no mesa card. its working fine, not crashes.
Time to create page: 0.230 seconds
