Daughterboard inputs not recognized in HALMETER
9 years 2 weeks ago #100495 by Dubmfg
Im using ADMIN HALMETER from within Pathpilot itself. Also, ADMIN HALCMD SHOW does not ellicit a response in Pathpilot.
I couldnt get a response in Terminal with dmesg | grep 6i25. Am I doing that wrong?
I've attached my logfiles
File Name: pathpilotlog.txt
File Size:38.01 KB
File Name: systeminfo.txt
File Size:66.31 KB
File Name: logfiles.zip
File Size:11.1 KB
9 years 2 weeks ago #100497 by PCW
Try dmesg | grep 5i25
9 years 2 weeks ago #100498 by Dubmfg
Derp, it reports as a 5i25. Shoulda remembered
File Name: report.txt
File Size:3.08 KB
9 years 2 weeks ago - 9 years 2 weeks ago #100504 by smgvbest
I see in your log you originally used the incorrect bit file and the last entry was the correct 5i25-7i76x2.bit
have you noticed any difference since that change?
the tormach bit file does not support the 7i76 so it would be suspected as a problem.
I'm at work and that was a quick look.
I wouild love to see linuxcnc and/or tomach to timestamp log file (pet peeve of mine)
Last edit: 9 years 2 weeks ago by smgvbest.
9 years 2 weeks ago #100509 by Dubmfg
Well yes, I swapped the bitfile for the 7i76 compatible one and am working on the .hal to use the inputs from the 7i76 instead of Tormach`s card. Where is the tormach timestamp logfile located?
9 years 1 week ago #100584 by Dubmfg
Ideas anyone? Ive been poking around forever and cant get anything meaningful out of my inputs still :(
Time to create page: 0.172 seconds
