Daughterboard inputs not recognized in HALMETER
8 years 11 months ago #101181 by andypugh
If you don't have a door then I would certainly remove all that door interlock logic.
But not before making a note of where all the door interlock logic goes to. You probably need to make sure that those inputs are satisfied by simpler routes.
Keep the debounce too, phantom limit triggers from electrical noise can be very annoying.
8 years 11 months ago #101200 by Dubmfg
So I've been playing with removal of the door logic, and I managed to make the Z axis which was working for homing not work. I'm comparing the files now to see what it could have been that broke it, hoping that its what is wrong with the X and Y axis. Not having much luck so far.
8 years 11 months ago #101201 by andypugh
It should just need something like:
net home-X-raw hm2_5i25.0.7i76.0.gpio-00-in debounce.0.0.in net home-X-filt debounce.0.0.out axis.0.pos-lim-sw-in axis.0.neg-lim-sw-in axis.0.home-sw-in
For each axis.
(motion pins are listed here: linuxcnc.org/docs/2.7/html/man/man9/motion.9.html )
8 years 11 months ago #101203 by Dubmfg
Woohoo! Plugged in the logic from my Linuxcnc .HAL and edited a bit of the postgui and now Its all working! Will post what worked for future people (likely me) to use as a reference for this combination.
8 years 11 months ago #101209 by Dubmfg
Attached is my funtioning HAL, POSTGUI, and INI
File Name: tormach_11...1-02.ini
File Size:6.38 KB
File Name: postgui_to...1-02.hal
File Size:4.27 KB
File Name: tormach_mi...1-02.hal
File Size:16.4 KB
Time to create page: 0.120 seconds
