Daughterboard inputs not recognized in HALMETER
9 years 1 week ago #100692 by Dubmfg
So, got all booted up into LinuxCNC, made a new config for my mill and opened up Axis. Within Halmeter there I am able to successfully see myself tripping my inductive limit switch that I have wired to INPUT-01. So this leaves me wondering why it wont read into Pathpilot. Im going to compare the two hal files and see if theres any glaring omission I should add.
9 years 1 week ago #100704 by smgvbest
Hi
Haven't given up, just been looking and I see something in you hal file. you have
loadrt hm2_pci config=" num_encoders=0 num_pwmgens=1 num_3pwmgens=0 num_stepgens=5 "
try changing to
loadrt hm2_pci config=" num_encoders=0 num_pwmgens=1 num_3pwmgens=0 num_stepgens=5 enable_raw sserial_port_0=0xxxxx"
see if that makes a difference
9 years 1 week ago #100705 by Dubmfg
That did not make any change, I saw that as well and tried it in my comparison I just did.
From running in native linuxCNC I now know that Halmeter is dynamic, so I should be able to see the changes there live.
9 years 1 week ago #100772 by smgvbest
can you provide your
*.ini
*.hal including the postgui.hal files
I'd like to run them on my set up which I know is working and see if I can reproduce your problem.
if I can then troubleshooting becomes much easier
9 years 1 week ago #100776 by Dubmfg
Yup, will do tomorrow when Im back in the shop. Thanks!
9 years 1 day ago #101040 by Dubmfg
File Name: postgui_to...mill.hal
File Size:6.05 KB
File Name: tormach_1100-3.ini
File Size:6.32 KB
File Name: tormach_mill_5i25.hal
File Size:20.33 KB
File Name: tormach_mill_base.ini
File Size:6.18 KB
Time to create page: 0.063 seconds
