Daughterboard inputs not recognized in HALMETER
9 years 3 weeks ago #100185 by Dubmfg
I do believe it is updated dynamically if I remember correctly, but I'm not able to see changes to pins at the moment of course
9 years 3 weeks ago #100189 by PCW
The way to check is to look at some pin that does change (say a position pin when in motion)
9 years 3 weeks ago - 9 years 3 weeks ago #100190 by Dubmfg
So by forcing debounce.0.0.in to 1 I'm able to force the machine into Machine.ok TRUE.
I can't however monitor the pins while jogging the axis to see if they change dynamically in Halmeter or Halscope, as they go to the background as soon as I try to change screens in pathpilot.
Last edit: 9 years 3 weeks ago by Dubmfg.
9 years 2 weeks ago - 9 years 2 weeks ago #100240 by smgvbest
Quick question as I don't see it asked
the input on the 7i76 is sinking inputs which means you must supply a positive voltage to them so that a value greater than 50% of the field power is applied to be read. If have a limit switch, one side goes to the field power the other side goes to the input pin.
Want to be sure we're not looking at a hardware issue as this would explain the behavior your seeing.
if you put one end to ground instead and the other to the input it would never see a change in state to register the switch being tripped.
hopefully it's that simple
Last edit: 9 years 2 weeks ago by smgvbest.
9 years 2 weeks ago - 9 years 2 weeks ago #100246 by Dubmfg
I've measured +24v to the pin when the limit switch is triggered. Pin 1 on SB6 is also directly wired from +24V on the power supply plug to it, as an always on signal for this testing.
Last edit: 9 years 2 weeks ago by Dubmfg.
9 years 2 weeks ago - 9 years 2 weeks ago #100254 by smgvbest
ok that's good, can you from a command prompt do a
dmesg | grep 6i25 and attach the output
also with pathpilot running in the MDI do a ADMIN HALCMD SHOW
then also attach your /home/operator/gcode/logfiles/pathpilotlog.txt
also, how are you running halmeter? are you starting it from within pathpilot with a ADMIN HALMETER?
please?
Time to create page: 0.348 seconds
