- Thank you received: 358
rodw wrote: [Anyway, it will be pretty trivial with mesa cards providing enough outputs. The beauty of LInuxcnc is its so extensible. Here is all the code you need for 2 zones utilising a 2 position flap so 4-6 zones would not need much more.
pin in float position "Motion signal for Axis position";
pin out bit trigger "True if downdraft segment should be triggered";
param rw float cutover "Absolute axis coordinate above which triggers zone change";
