- Thank you received: 7
Ok, so chinese "cut40" has its own category: HV with no pilot arc = with just one wire going to the torch (or the antenna) = noisy as **** when the spark has nowhere to jump. With one wire there is no way to have a pilot arc - unless you hack it and add another wire to the nozzle. This works a little bit but certainly the heat input is too big for the nozzle. The same thing happens when people drag the nozzle on the material. I imagine it would work better if there was a return wire from the nozzle with some kind of current detector on it, to allow only very little current to flow when the pilot arc is on. Once the arc jumps to the material the current would ramp to normal value - isn't it like this in more expensive models with pilot arc? Is it possible to use such cheap power source with different kind of torch like the air switch type (is that the blowback?)?tommylight wrote:
Pilot arc = has the means to strike an arc all on it's own even when far from material and more importantly it can maintain that arc for some time without touching or moving any torch parts. This makes it very reliable and that is why almost all expensive ones have one of two types of pilot arc, and this is why cheap Chinese ones insist they have pilot arc although most of them do not.
The implications of using a pilot arc are far from simple and it takes quite a bit of explaining so i will try a short version:
there has to be some provision inside such power sources to protect the rectifier inside, the rectifier can not be disconnected and connected again after a successful arc transfer as that would cause much more trouble etc etc.
Utilizing a blowback start, and an electronically controlled pilot arc,
Blowback starting mechanism to initiate the cut, which eliminates high frequency interference from the starting circuits
The ignition console is attached to the outside of the rear panel of the power supply enclosure. The ignition console uses a spark-gap assembly. The ignition console converts 120 VAC control voltage from the power supply into high-frequency and high-voltage pulses (9–10 kV) to initiate the pilot arc at the torch electrode-nozzle gap. The high-voltage, high-frequency signal is coupled to the pilot arc lead.
jmr wrote:
Tommy: once You get some sleep please tell me if you have seen one of these in any machines: image missing http://www.profelectro.info/wp-content/uploads/motorCircuitoImpresso4.jpg
I found some general info: www.motioncontroltips.com/faq-servo-pancake-motors-work/tommylight wrote:
No, but sure looks like the internal coil of very slim motor with no metal core. Interesting, i wonder what is the efficiency of such things?
