Snuggly's Plasma Build
- Grotius
- Thank you received: 2349
28 Nov 2018 22:17 #121557
by Grotius
Replied by Grotius on topic Snuggly's Plasma Build
What is this?
Located in your plasma.hal :
setp hm2_7i96.0.dpll.01.timer-us -50
It looks like a timer with a negative value of -50 nano seconds?
Watchdog is 5 million nano second's?
Okey i understand stepgen control type = 1.
Nice you have no error's moving around. Keep up the good work !!
Next item would be to connect your z axis. Read about Tom's stepper solution for z axis.
The following user(s) said Thank You: snugglylovemuffin
- snugglylovemuffin
- Thank you received: 11
28 Nov 2018 22:29 #121558
by snugglylovemuffin
Replied by snugglylovemuffin on topic Snuggly's Plasma Build
My NC float switch is presenting a bit of a problem, I can't put it as in-not without linuxcnc error "pin doesn't exist".
I'll change it to NO for now, see if it has any problems. A potential fix is welcome however.
- Thank you received: 4652
28 Nov 2018 22:56 #121559
That's fine for the DPLL, it's a relative timing.
Replied by andypugh on topic Snuggly's Plasma Build
28 Nov 2018 22:56 #121560
My NC float switch is presenting a bit of a problem, I can't put it as in-not without linuxcnc error "pin doesn't exist". .[/quote
Which pin is it currently connected to?
- Thank you received: 5321
28 Nov 2018 23:09 - 28 Nov 2018 23:12 #121561
Replied by PCW on topic Snuggly's Plasma Build
The pin name is blah.blah.blah.in_not note underscore, not dash
Now that you have a configuration running, you might consider using "halshow" or "halcmd show pin"
to get the names of all available pins, there really is no reason to guess these names since LinuxCNC can
list them for you
list them for you
Last edit: 28 Nov 2018 23:12 by PCW.
- snugglylovemuffin
28 Nov 2018 23:49 #121564
Yeah, that was my mistake. Still getting used to the specific notation
29 Nov 2018 00:04 #121565
Too late to change it now, but it probably would be more consistent as a dash.
- snugglylovemuffin
03 Dec 2018 21:31 #121769
I started going through my machine and setting up the Proma 150 according to Tommy's instructions - link below
During the Proma's "test", it was showing an inconsistent ARC-OK and wasn't jogging the Z axis up and down at all.
(forum.linuxcnc.org/49-basic-configuratio...thc-150-setup-issues)
- snugglylovemuffin
04 Dec 2018 00:08 #121787
To forego PCW's ire, I've taken to hal config to sort out my Z axis (starting to get the hang of it).
So far the only working portions of my Z axis is pos-cmd. Since I know the general problem, I'm keep diving into the joint 3 connections and see if I can't figure out where the failed connection is
04 Dec 2018 00:50 #121790
I don't think PCW has any ire, he seems extraordinarily patient.
I, on the other hand, get quite sarcastic at times.
Time to create page: 0.148 seconds
