Snuggly's Plasma Build
  • snugglylovemuffin
  • snugglylovemuffin's Avatar Topic Author
  • Elite Member
  • Elite Member
11 Jan 2019 21:55 - 11 Jan 2019 21:57 #123994 by snugglylovemuffin
Replied by snugglylovemuffin on topic Snuggly's Plasma Build
I was wrong, pins 13 + 14 are the problem (relay). My relay switches low which I completely spaced.
Doesn't seem to explain why pins 12,13,14 were acting strangely.
Last edit: 11 Jan 2019 21:57 by snugglylovemuffin.
11 Jan 2019 23:53 #124001 by tommylight
Replied by tommylight on topic Snuggly's Plasma Build
Pin 13 is input, pin 14 is output.
  • snugglylovemuffin
  • Elite Member
  • Elite Member
12 Jan 2019 00:21 #124003 by snugglylovemuffin
I know, just had them wired without power.
My entire TB3 output and common are all switching on and off; this clearly isn't a HAL or physical wiring issue. I'm wondering if somehow the board is faulty.
PCW, if you'd like to weigh in here; I have not even entertained the notion of messing with EEPROM
12 Jan 2019 00:52 #124004 by PCW
Replied by PCW on topic Snuggly's Plasma Build
If the input common is switching you probably have a wiring or power supply issue
  • snugglylovemuffin
  • Elite Member
  • Elite Member
12 Jan 2019 01:30 - 12 Jan 2019 01:43 #124006 by snugglylovemuffin
Isolated inputs are working properly. It's just the outputs that aren't working properly by switching on/off. I've pulled wiring and it doesn't seem to make a difference. I'll check my PSU, however wouldn't my inputs be switching too if it was my psu?
Last edit: 12 Jan 2019 01:43 by snugglylovemuffin.
12 Jan 2019 02:21 - 12 Jan 2019 02:45 #124009 by PCW
Are the hal pins for the outputs changing?
7I96 isolated output hal pins are:
hm2_7i96.0.ssr.00.out-00
hm2_7i96.0.ssr.00.out-01
hm2_7i96.0.ssr.00.out-02
hm2_7i96.0.ssr.00.out-03
hm2_7i96.0.ssr.00.out-04
hm2_7i96.0.ssr.00.out-05
Last edit: 12 Jan 2019 02:45 by PCW.
The following user(s) said Thank You: snugglylovemuffin
  • snugglylovemuffin
  • Elite Member
  • Elite Member
12 Jan 2019 05:25 #124015 by snugglylovemuffin
No, it's just the common pin. I erroneously read the GPIO instead of the SSR thread, my mistake. Power supply seems to be fine, but I'll try hooking it up to an isolated power supply just in case. It really is bugging me, there's no reason for it to be doing this. If hooking it up to a power supply doesn't work, does that mean the firmware is corrupted?
12 Jan 2019 12:53 #124028 by PCW
Not sure what you mean by the "common pin" (the outputs are individually isolated)
Firmware cannot really get corrupted and still load ( The FPGA checks the firmware when its loaded and will detect any changes from the valid original image )
If you have wired one side of all the outputs to a power supply pin (your output common) and this output common is not stable relative to the other power supply
pin, this is not something the 7I96 has any control over.
12 Jan 2019 14:48 #124033 by tommylight
NO!
It does mean something is very wrong with your wiring and/or power supply or one of the drives or....................
  • snugglylovemuffin
  • Elite Member
  • Elite Member
12 Jan 2019 18:49 - 12 Jan 2019 18:50 #124038 by snugglylovemuffin
In halshow: hm2_7i96.0.gpio.011 is switching between in /in_not (does this matter, am I reading the pin wrong?)
I don't believe I've tested this pin because it is the common and it didn't seem to matter. GPIO pins 0-10 are working as well as SSR relay pin hm2_7i96.0.ssr.00.out-00. (My mistake for reading the SSR as GPIO)
I believe that one of the issues was a Z soft limit of 0.25, which I have increased. The files Islander modified for me seemingly corrected this, I will check these files again to isolate the issue further.
Last edit: 12 Jan 2019 18:50 by snugglylovemuffin.
Time to create page: 0.980 seconds
