Snuggly's Plasma Build
- islander261
- Thank you received: 216
12 Dec 2018 22:42 #122323
by islander261
Replied by islander261 on topic Snuggly's Plasma Build
Use the configuration files I posted on Monday! The ones you just posted are old files that will not allow homing of the Z axis and have some other problems with inconsistent and illogical values in the .ini.
The following user(s) said Thank You: snugglylovemuffin
- snugglylovemuffin
- Thank you received: 11
12 Dec 2018 23:52 #122335
by snugglylovemuffin
Replied by snugglylovemuffin on topic Snuggly's Plasma Build
@rodw: I noticed that, which made it all the more confusing. I just went through all my wiring when I cleaned up my box, I'll check it again just to be sure.
@Islander261: I wanted to isolate the issues and deal with one variable at a time before changing up the files. I'll try them out right now.
Update in a few
Update in a few
- snugglylovemuffin
13 Dec 2018 20:57 #122385
@Islander261: here is the launch error
hm2/hm2_7i96.0: invalid token in config string: "num_ssrs=1"
hm2/hm2_eth: rtapi_app_main: Invalid argument (-22)
- Thank you received: 4144
13 Dec 2018 21:07 #122386
Thats what can happen when somebody writes something for you and does not have your hardware. All you need to do is to locate the line in John's config starting with
And replace it with the same line in your working config
Replied by rodw on topic Snuggly's Plasma Build
loadrt hm2_ethAnd replace it with the same line in your working config
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=0 num_pwmgens=0 num_stepgens=4"
- snugglylovemuffin
13 Dec 2018 21:12 #122387
Got it, that's what I did last time. I'll try it again and see how she chooches.
- islander261
13 Dec 2018 21:25 #122388
by islander261
Sorry, I misunderstood the hostmot2 documentation about requiring enumeration of solid state relay outputs. Do as Rod said. Also you will need to comment out or delete this line:
setp hm2_7i96.0.ssr.0.rate 1000000
- snugglylovemuffin
13 Dec 2018 21:31 - 13 Dec 2018 21:32 #122389
Excellent; it fired up well and I was able to activate my float without it throwing a "joint 3 on limit" error. I wasn't able to jog or home my Z axis. I'll load up some gcode and do some dry runs.
Last edit: 13 Dec 2018 21:32 by snugglylovemuffin.
- islander261
13 Dec 2018 23:55 #122394
by islander261
Ok, Z can't move yet. Add the following to Z axis section in Hays_Plasma....hal:
net z-enable <= joint.3.amp-enable-out
net z-enable => hm2_7i96.0.stepgen.03.enable
You should also consider changing the homing order in the .ini file to home the Z first.
[JOINT_3]
HOME_SEQUENCE = 0
[JOINT_2]
HOME_SEQUENCE = 1
[JOINT_1]
HOME_SEQUENCE = -2
[JOINT_0]
HOME_SEQUENCE = -2
I am still not clear about homing Z when using the TOMA THC.hal though it should work because as far as the THC.hal knows it is the same as a jog.
[JOINT_3]
HOME_SEQUENCE = 0
[JOINT_2]
HOME_SEQUENCE = 1
[JOINT_1]
HOME_SEQUENCE = -2
[JOINT_0]
HOME_SEQUENCE = -2
- snugglylovemuffin
14 Dec 2018 01:22 #122402
Thanks, hopefully that'll do it and report back with an update tomorrow.
- Thank you received: 7467
14 Dec 2018 06:19 #122411
Replied by tommylight on topic Snuggly's Plasma Build
2 nights ago i did some editing of the files that Icelander provided, it got to late so forgot to copy them to the USB but here is some info:
-there are some lines with DDT that are commented out in THC.hal, they have to be enabled for THC to work, so the lines regarding DDT have to be copied from stepper.hal to hayes_plasma.hal
loadrt ddt count=2
addf ddt.0 servo-thread
addf ddt.1 servo-thread
Also the lines regarding Estop-latch have to be copied there and the e-stop lines at the end of that file have to commented out.
- there are missing provisions for the spindle in the hayes_plasma.hal, so M3 or F9 will not work, they have to be added.
As a side note, it would have been much easier to use the servo version that is located here and just edit the lines concerning the Z axis and the servo to stepper on other axis.
forum.linuxcnc.org/show-your-stuff/34986...nuxcnc-and-proma-thc
loadrt ddt count=2
Time to create page: 0.123 seconds
