Another plasma component...
7 years 9 months ago #123463 by newbynobi
Replied by newbynobi on topic Another plasma component...
Hallo Phil,
the mentioned link will not copy the needed hal widgets to the needed locations, so this might cause problems.
I made a howto for linux MINT 19 Mint 19 and glade
Please check the steps regarding the installation of glade 3.8.6
Norbert
7 years 9 months ago #123469 by andypugh
Replied by andypugh on topic Another plasma component...
phillc54 wrote: The worst problem that I have experienced with different panels over a number of years on both LCNC 2.7 & Master is when doing something simple like changing the height or width of a widget Glade just shuts down, losing all edits
For the reasons you have noticed, I often edit glade files with a text editor for simple things like renames and resizes.
7 years 9 months ago #123514 by phillc54
I do have all the hal widgets so maybe it was your link that I did follow, I cannot really remember...
I did not think of doing something simple like that, It seems I like to make things complicated for myself.
Cheers, Phill.
7 years 9 months ago #123527 by phillc54
Well I have settled down now and gone back to to the Gladevcp panel for the example config...
Cheers, Phill
7 years 9 months ago - 7 years 9 months ago #123811 by phillc54
I have pushed an example config for Gmoccapy which is still a work in progress.
It appears under Gmoccapy in the Configuration Selector.
I am not sure about SpinButtons as I do not have a touchscreen so I am not sure what are the correct widgets to use.
github.com/phillc54/linuxcnc-plasmac
Warning: Spoiler!
Cheers, Phill
Last edit: 7 years 9 months ago by phillc54.
The following user(s) said Thank You: sevaz
7 years 9 months ago #123812 by rodw
Looks nice Phil.
Time to create page: 0.738 seconds
