Another plasma component...
7 years 11 months ago - 7 years 11 months ago #121279 by rodw
bevins wrote: Is there install instructions? I want to try and implement this on this machine I am building.
I have not installed it yet but essentially you would follow the official build process documented here
linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
but substituting Phils Git (see link in first post). I would probably use a different folder name to linuxcnc-dev, maybe something like linuxcnc-plas so you can build master branch from source as well if you want to.
Then it would be a matter of copying the sim into a working config folder and merging in your working table config. Then you are away!
Last edit: 7 years 11 months ago by rodw.
7 years 11 months ago #121287 by phillc54
Exactly as rodw suggested...
7 years 11 months ago - 7 years 11 months ago #121288 by phillc54
I have just posted another update.
The component has better error checking for some invalid config settings.
The format of the materials file has been changed, it is still only a flat text based file but it is more human readable as it is now in the same format as the LinuxCNC ini file.
If you have an existing materials file it will be automatically updated on first load.
The materials file can now be edited while LinuxCNC is running and can be reloaded from the Reload button in the Config tab.
Some default settings for the Config parameters have also been changed.
Last edit: 7 years 11 months ago by phillc54.
7 years 10 months ago #122244 by phillc54
Another update...
I have managed to merge the reverse-run commits into the current master so the PLASMAC repo now has reverse run activated.
I have also fixed the reverse run issue of slow accelleration.
Cheers, Phill.
7 years 10 months ago #122253 by rodw
phillc54 wrote: Another update...
Cheers, Phill.
Awesome Phil, very exciting!
7 years 10 months ago #122454 by grijalvap
Replied by grijalvap on topic Another plasma component...
Very Nice work, I did a component similar component in the past and it is working, but this is better, I will install and use this one.
Start the cutting process at a certain point after a cutting problem has been a big problem for me (actually I couldn't yet).
can someone explain how is this implemented on this branch or how I can implement?
Time to create page: 4.326 seconds
