Another plasma component...
7 years 11 months ago #120731 by islander261
Replied by islander261 on topic Another plasma component...
Here are some thoughts on this.
1. What is your intended user of this component? If it is the hobbyist/small shop using a modern air plasma then this is over the top and will not improve their cut quality or consumable life. Older HF units may get some benefit from this by way of improved start times. Higher end oxygen or mixed gas plasma units that use HF start ( late model industrial) will benefit from this approach.
2. My system currently uses ohmic sensing with automatic fall back to the float switch if contact is not sensed. The two inputs are joined by an OR2 hal component and the source of the probe signal is checked when the state changes. Ohmic sensing isn't easy, you need to check for a number of error conditions and try and clear them or pause for operator intervention ( I do this using a Gcode probing subroutine). Remember good IHS is the holly grail of plasma cutting with air plasma.
3. Rod W. has the right plan. Separate components for each function that are either joined together by hal file or an overall component is the way to go. The plasma world is very fragmented with different hardware in many installations, an easy way to customize functionality to deal with unique hardware and CAM solutions is much easier to handle if presented in bite sized pieces.
The following user(s) said Thank You: phillc54, rodw
7 years 11 months ago - 7 years 11 months ago #120734 by phillc54
The original intended user is me, definitely a hobbyist, using air plasma, zero experience...
After a lot of forum reading (here and elsewhere) I thought that single component would suit my purpose as it would lead to a simpler hal file.
I got the basics working (in sim mode) and as it is relatively easy to add extra functions without much additional overhead it grew from there so I decided to share what I came up with in the hope that someone may find it useful and also for feedback as to what is really required.
I was also hoping that a new (to linuxcnc) user may find it a relatively easy way to get a functional plasma system up and running.
Last edit: 7 years 11 months ago by phillc54.
7 years 11 months ago #120735 by rodw
islander261 wrote: 3. Rod W. has the right plan. Separate components for each function that are either joined together by hal file or an overall component is the way to go.
There are a few reasons I think like this
1. That is consistent with the LinuxCNC component approach. Many standard components are < 10 lines of code.
2. I was always taught that if you could not see a procedure on a single screen or page, it is too long and it needs to be broken up.
3. I was adding pieces of the puzzle on a progressive basis.
4. Many of the pieces are totally unrelated. Eg corner lock/velocity anti-dive and torch sampling have nothing in common.
5. A small component is much easier to debug where we don't have access to a debugger to step through code in an interrupt service routine environment.
But Phil, you have worked out how to use git so you have a great opportunity to get your code included in LinuxCNC then I have so keep up the good work. Like you I knew nothing about CNC or plasma when I started!
The good news is I finally found my mouse for my Linuxcnc box today so I might be able to try some of this stuff!
7 years 11 months ago - 4 years 5 months ago #120736 by phillc54
rodw wrote:But Phil, you have worked out how to use git
Attached is my goto doc when using git.
Some of the url's may be out of date but...
Last edit: 4 years 5 months ago by phillc54.
The following user(s) said Thank You: tommylight, rodw, islander261
7 years 11 months ago #120737 by rodw
Thanks Phil, now everything except reverse run is in master, I might see if I can clone master branch and see if somebody will incorporate some of my components into master.
7 years 11 months ago #120738 by billykid
Replied by billykid on topic Another plasma component...
the main problem for the pierce is the material that boils and inexorably ruins the nozzle. generally it is improved by starting first at very low speed so that the melted material is left behind by saving the nozzle.
thanks for the job
Time to create page: 1.205 seconds
