- Thank you received: 27
Another plasma component...
- rene-dev
7 years 11 months ago #120115
by rene-dev
Replied by rene-dev on topic Another plasma component...
seen it, I try to merge it.
The following user(s) said Thank You: phillc54, tommylight, rodw
- phillc54
- Thank you received: 2100
7 years 11 months ago #120124
by phillc54
Rod Wrote:
In normal use with this config (with the F word remap) the original feed rate comes from the feed rate set in the gladevcp panel.
Cheers, Phill
The other feature mentioned that may be useful was the state tags branch. This has been suggested to be a possible solution to knowing the original feed rate instead of using remapping. I've looked at the code and have seen the new structure but don't know how you would access it from the component.... Some discussion on Issue 440 here but I could never find out how it might
Cheers, Phill
- rene-dev
7 years 11 months ago #120142
by rene-dev
I just merged reverse run into master, please test if everything works.
external offsets is next... where can I find the latest version of that?
Rene
Rene
- phillc54
7 years 11 months ago #120149
by phillc54
Thanks Rene, much appreciated.
I will check this out later today.
External offsets is the dgarr/external_offsets branch.
Cheers, Phill
Cheers, Phill
- phillc54
7 years 11 months ago #120151
by phillc54
I have just pushed another update...
The F word remapping is now scales correctly for all imperial/metric combinations.
THC calculations only use the user requested feed rate.
Cheers, Phill.
Cheers, Phill.
- rene-dev
7 years 11 months ago #120153
by rene-dev
ok, scratch that. I just had to revert, as there are problems. working on it...
Time to create page: 0.742 seconds
