Another plasma component...
7 years 11 months ago #120159 by rodw
rene-dev wrote: I just merged reverse run into master, please test if everything works.
external offsets is next... where can I find the latest version of that?
Rene
Rene, On 20 October, on the developers email list, Dewey said
>The current single patch is:
i updated the commit message so the current single commit is 784db0335:
github.com/LinuxCNC/linuxcnc/commit/784d...5362a0dae498290d8786
Not sure that is useful for you. Thank you very much for committing these things. It will make life easy for many of us!
7 years 11 months ago #120195 by Grotius
Replied by Grotius on topic Another plasma component...
Rod,
SQL is working in Linuxcnc. For making a c component mysql.h is missing, it's not in the include directory, so this takes more time.
We can also use different version's of SQL. lite_version
Maybe the best way is to test a dynamic input set up.
7 years 11 months ago - 7 years 11 months ago #120198 by rodw
Grotius wrote: Rod,
Yes, I use SQLite in my example. When I get a bit more data in the system and am certain the database schema is correct, I've written I will raise another thread as its kind of off topic on this one. I've got to define the gasses better as some machines have both cutting gas and shielding gas. I don't really think the data needs to be accessed by a component in C. Its really a user interface thing so setting fields/pins in the GUI in user space should suffice. There was a proposal from Andy quite some time ago to use SQL for tool tables:
wiki.linuxcnc.org/cgi-bin/wiki.pl?ToolDatabase
and somehow, we have a SQL schema in the LinuxCNC repo already.
github.com/LinuxCNC/linuxcnc/blob/master...ql/schema-simple.sql
Last edit: 7 years 11 months ago by rodw.
7 years 11 months ago #120200 by rodw
Well, reviewing what happened overnight, it looks like the devs sorted out the external offset branch so now all of the base software has been updated and placed in master branch:
  • Trajectory slow down bug
  • Reverse Run
  • External Offsets
So well done and thanks to Phill for building a repo that put the spotlight on these features and getting them into master branch
Also thanks to Rene for actioning this at the developer level.
So now Phill, you only need to worry about your component and GUI interface! Once tested, I'm sure the sim and component can be pushed from your repo to master..
The following user(s) said Thank You: phillc54, tommylight
7 years 11 months ago #120209 by rene-dev
Replied by rene-dev on topic Another plasma component...
ignore all the sql stuff, it all not complete. thats another thing Im working on...
external offsets has been merged, but I had to revert the reverse run. I try again tonight, I think I know how to fix it now.
The following user(s) said Thank You: phillc54, tommylight, rodw
7 years 11 months ago - 7 years 11 months ago #120290 by Grotius
@Reve_dev,
You can compare your code for the reverse run with this one : github.com/grotius-cnc/stable
I hope it can be usefull for you. It has also the external offset branche in it. Discus the glade speedwidget that the minimum value
can be set to -1.
Last edit: 7 years 11 months ago by Grotius.
Time to create page: 0.364 seconds
