Another plasma component...
7 years 3 months ago #140636 by phillc54
Can you try decreasing the feed rate while you are cutting a hole
7 years 3 months ago #140637 by phillc54
Franklin wrote: Hi Phill, can you explain how the off delay should work?
I thought that should be a delay after the cut is finished before Z lifting up.
But the torch is stays on when the z axis is lifting up. It's right?
It possibly should be this is my any inexperience showing.
Some input on this would be appreciated.
7 years 3 months ago #140675 by islander261
Replied by islander261 on topic Another plasma component...
Phill
Hi, I have been away from plasma cutting since the first of the month because of some medical issues. I want to get caught up with the latest PlasmaC version. I have always used a RIP build because of my gantry machine. Are you planning any major changes to PlasmaC soon, should I wait before cloning the new master branch?
7 years 3 months ago #140677 by tommylight
Replied by tommylight on topic Another plasma component...
Glad you're feeling better.
7 years 3 months ago #140695 by phillc54
I was thinking of adding a torch off via a digital pin for 'overburn' of whatever it is called.
7 years 3 months ago #140696 by Grotius
Replied by Grotius on topic Another plasma component...
Phill,
Do you mean ignition time out?
Time to create page: 0.229 seconds
