Another plasma component...
7 years 2 months ago #142796 by phillc54
Here you go.
  • thefabricator03
  • Visitor
  • Visitor
7 years 2 months ago - 7 years 2 months ago #142797 by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
Ok set up a program using your post and get this result.Text does not come out right and program wont run.
Last edit: 7 years 2 months ago by thefabricator03.
7 years 2 months ago - 7 years 2 months ago #142799 by phillc54
Can you send me the job file.
We may be looking at the tool stuff wrong. I don't really know enough about it.
It may well be that we need Tool #1 as the torch and Tool # 2 as the scribe.
You could try that by adding a Tool2, setting Tool1 offsets to zero and Tool2 offsets to suit the scribe then try the MDI code I sent before but use T1 and T2.
I think I will have a play around on my mill tomorrow.
Edit: It definitely won't run in Pierce Only mode ;)
Last edit: 7 years 2 months ago by phillc54.
  • thefabricator03
  • Visitor
  • Visitor
7 years 2 months ago #142800 by thefabricator03
Attached is the file,
I will try out the tool stuff as I have been playing around with the PlasmaC file and getting now where.
At least its scribing half ok now,
Still a long way to go but at least its kinda working.
  • thefabricator03
  • Visitor
  • Visitor
7 years 2 months ago - 7 years 2 months ago #142801 by thefabricator03
Ill just show you this in case anyone can point out what is happening,
This is my torch at 0,0,
When I run the program it moves sightly to the scribe mark and the scribe works in the top right corner,
But when it goes to cut the holes the torch moves to this position which I would of though is a negative position ,
Attachment not found
This is the sheetcam picture of the part,
7 years 2 months ago #142802 by phillc54
Where does the text come from, is in the dxf file or is it done later by sheetcam.
When you have the torch at 0,0 where does it end up if you MDI a T1M6G43 then a G0X0.1Y0.1?
Time to create page: 1.194 seconds
