Another plasma component...
7 years 5 months ago - 7 years 5 months ago #132914 by rodw
John, I don't see the point of using a battery other than to confirm things are in the ball park. Mesa give us calibration data at 10 volts and you should always know the voltage division. So its easy to work out the scale from there if you calculate the full scale reading at 10 volts.
eg:
50:1 = 10 * 50 = 500 volts full sale -- 10/500 = 0.2
30:1 = 10 * 30 = 300 volts full scale -- 10/30 = 0.0333
16:1 = 10 * 16 = 160 volts full scale -- 10/16 = 0.0625
The only proviso is that the THCAD can sometimes see the resistor network on the CNC board as belonging to it (eg. Everlast). But the battery test will not identify the Everlast issue. The only way to do that is put say 100 volts through the divider and see what you get. ( I used 2 x 48 volt power supplies).
So I would just see on your first cut if the voltage is somwhere near the book settings. If its way out, you have a problem (like the Everlast). 03, I don't think your Hypertherm will give wrong results as my Thermal Dynamics did not.
Last edit: 7 years 5 months ago by rodw.
7 years 5 months ago #132915 by phillc54
I don't think it is that simple, we are actually using the scale to convert the velocity from the encoder to a voltage.
Cheers, Phill.
7 years 5 months ago #132918 by JTknives
Lol there it is right there in broad daylight. I was searching through all the files lol. But now I have another problem, it will only take a max of 100 as an offset.
7 years 5 months ago #132919 by phillc54
JTknives wrote: Lol there it is right there in broad daylight. I was searching through all the files lol. But now I have another problem, it will only take a max of 100 as an offset.
You must have an older version, that was corrected recently.
Or can change the lines in plasmac_config.py (around line 54) to:
self.builder.get_object('arc-voltage-offset').set_digits(1) self.builder.get_object('arc-voltage-offset-adj').configure(0,-99999,99999,0.1,0,0) self.builder.get_object('arc-voltage-scale').set_digits(6) self.builder.get_object('arc-voltage-scale-adj').configure(1,-999,999,0.000001,0,0)
If you want a quick fix without any later updates.
Cheers, Phill.
7 years 5 months ago - 7 years 5 months ago #132920 by JTknives
I would rather just update to the current version but dont want to loose any of my work I put into my hal and ini files. Is there an easy way to update to current?
Last edit: 7 years 5 months ago by JTknives.
7 years 5 months ago #132921 by JTknives
Is it really as simple as
git pull make sudo make setuid
Time to create page: 0.794 seconds
