Another plasma component...
7 years 5 months ago - 7 years 5 months ago #133251 by andypugh
rodw wrote:
phillc54 wrote: Particularly if you work with the arcane docs editor used in the linuxcnc environment. I hope Andy pops in and points you in the right direction on that one!
The manpages are written on groff / trof or something like that, but I don't think that is the way to document this.
(And if you write a .comp then the compiler converts for you automatically)
The "real" docs are written in Asciidoc, and that's much friendlier. You can even edit and preview directly in Github,
Here is some documentation from the LinuxCNC source viewed "raw"
raw.githubusercontent.com/LinuxCNC/linux...c/config/pncconf.txt
As you can see, it is entirely legible even as markup source.
It gets pre-rendered by Github in the default view:
github.com/LinuxCNC/linuxcnc/blob/master...c/config/pncconf.txt
Last edit: 7 years 5 months ago by andypugh.
The following user(s) said Thank You: phillc54, rodw
7 years 5 months ago - 7 years 5 months ago #133254 by sevaz
Replied by sevaz on topic Another plasma component...
JTknives wrote: So when I trip the ohmic or floating z switch after I run m03s1 I get a error saying “ohmic probe/floating switch detected before probing program is paused”
You should probably check probe height in the config tab
Last edit: 7 years 5 months ago by sevaz.
7 years 5 months ago #133256 by JTknives
When I try and jog any of the axis I get a “joint # fallowing error” where the # corasponds to x=0 y=1 and z=2. Also the control trips out and has to be turned back on.
7 years 5 months ago #133274 by JTknives
Weird thing is if I load imperial_plasmac all the axis run fine but if I run the mymachine from the configuration selector it runs all axis fine.
7 years 5 months ago #133287 by rodw
JTknives wrote: When I try and jog any of the axis I get a “joint # fallowing error” where the # corasponds to x=0 y=1 and z=2. Also the control trips out and has to be turned back on.
Are you running a metric machine? Form memory one of the pncconf defaults is wrong for metric and will cause that. I've just forgotten the exact details. Maybe ask in another section where more people (and PCW) will see it.
7 years 5 months ago - 7 years 5 months ago #133288 by Grotius
Replied by Grotius on topic Another plasma component...
Mostly of time a following error can be solved by the ferror factor. Just attached a example to solve this. It works for servo (PID) and stepper systems. Interface type indepenent.
[AXIS_X] MIN_LIMIT = -10000 MAX_LIMIT = 6560 MAX_VELOCITY = 160 MAX_ACCELERATION = 350 [JOINT_0] TYPE = LINEAR HOME = 0.0 MAX_VELOCITY = 160 MAX_ACCELERATION = 350 STEPGEN_MAXACCEL = 750 SCALE = 187.25 # You see over here Ferror and Min_ferror. They are important to avoid following error's. FERROR = 1 MIN_FERROR = .25 MIN_LIMIT = -10000 MAX_LIMIT = 6560 #HOME_LATCH_VEL = -1 #HOME_SEARCH_VEL = -20 #HOME_FINAL_VEL = -1 #HOME_IGNORE_LIMITS = YES #HOME_OFFSET = -2 #HOME_SEQUENCE = -2 HOME_LATCH_VEL = 0 HOME_SEARCH_VEL = 0 HOME_FINAL_VEL = 0 HOME_IGNORE_LIMITS = YES HOME_OFFSET = 0 HOME_SEQUENCE = 0
Last edit: 7 years 5 months ago by Grotius.
Time to create page: 0.272 seconds
