Oxy/Fuel table
- islander261
- Thank you received: 216
07 Dec 2018 21:25 #122020
by islander261
Replied by islander261 on topic Oxy/Fuel table
You still need to make sure your G64 parameters are set correctly, this is a big change from running Mach3.
The post can be changed so that it prints a F feed rate with each movement by changing line 318 to:
post.Number (" F", feedRate * scale, "0.0##")
This will make busy looking Gcode.
- Grotius
- Thank you received: 2349
07 Dec 2018 21:26 #122021
by Grotius
Replied by Grotius on topic Oxy/Fuel table
@John,
I can restart from line directly in linuxcnc, in all circumstances.
It works directly whithout setting any parameter or editting files.
The code behind the program start button in grotius gui :
startline = int(self.widgets.start_entry.get_text())
self.c.auto(self.cnc.AUTO_RUN, startline)
1. It read's in the start_entry text box value.
2. Then it uses a linuxcnc Auto_run command combined with a start line number.
But for me i don't use start lines anymore. With negative adaptive feed it's easyer to move a little back
on cutting pat'h. Client's see this as an advantage related to Mach3. Also the real time height cutting path's plot's
are a big plus related to Mach3.
- Grotius
07 Dec 2018 22:02 #122025
by Grotius
File search in axis is horrible. I can not find my external hard drive to open a ngc file.
Restart from selected line seems to be impossible, and it exceeds limit's. Pfff. Why don't they set the limits to max?
So i found out that axis is horrible to start with at these option's. And why after so many year's?
Are they sleeping in the dev section?
- islander261
07 Dec 2018 22:53 #122026
by islander261
Grotius
The OP is using CommandCNC the UI is much different than yours.
The parameter setting is because LinuxCNC will skip all of the preamble Gcode when it jumps to the selected start line.
- w4swasey
09 Dec 2018 20:34 #122113
by w4swasey
Replied by w4swasey on topic Oxy/Fuel table
G64 parameters?
- w4swasey
09 Dec 2018 20:47 #122114
by w4swasey
Another thing I noticed today Is I set up a 4' X 8' sheet today (43) of the same part using a combination of array & copy. Only the very first part had feed rate in the G code.
So if I loose cut anywhere, the only place I can re start is on the very first part unless I go back to sheetcam & disable all parts up to the current one & run post process again
- Thank you received: 4144
09 Dec 2018 21:17 #122115
Replied by rodw on topic Oxy/Fuel table
It was suggested that you enter the freedrate manually in the MDI window before restarting.
You could also consider modifying the OnNewPart() function in the post processor file to insert the feedrate but that won't help if you want to restart mid part.
Something like this should insert the feedrate
post.ModalNumber (" F", feedRate* scale, "0.0###")
The following user(s) said Thank You: w4swasey
- islander261
09 Dec 2018 22:07 #122118
by islander261
This is expected behavior with a modal feed rate. This isn't a problem with plasma because the plunge feed rate is not the same as the linear feed rate. Because of using the ramp plunge on the leadin there is no separate plunge move.
Edit the post as above and you will get the feed rate in every linear move (G01) move.
- w4swasey
09 Dec 2018 22:08 #122119
by w4swasey
I want to thank everyone for the input... Thing is I understand almost nothing about changing or modifying a post processor. I envy you guys that understand it.
Some of my problem is I'm vision impaired. I find it very hard to read these days without a good bit of magnification. Lost my one good eye about 4 years ago. I just refuse to give up & be labeled "disabled".
I used to be able to pick up a tech or service manual to just about anything & figure it out on my own.
Something like this should insert the feedratepost.ModalNumber (" F", feedRate* scale, "0.0###")
- islander261
09 Dec 2018 22:33 #122120
by islander261
Ok
Please find attached modified post.
G64 sets the tracking tolerance for your moves, if you don't use it you will get rounded corners because the feed rate won't slow for corners, the line from your post is:
G64 P0.010 Q0.001 (tracking tolerances set to 0.01)
Time to create page: 0.267 seconds
