Configuring Plasmac - a complete THC/plasma config for any hardware
7 years 5 months ago - 7 years 5 months ago #133430 by JTknives
OK i don't know what i have done and where my mix up is but i cant get awaw from joint errors. I had working files at one time but that was before i got the plasmac working. I also noticed that my option buttons are missing and i no longer see the halshow button or any of the other buttons. i think something has gotten messed up trying to keep up with the updates. here are my files.
Last edit: 7 years 5 months ago by JTknives.
7 years 5 months ago - 7 years 5 months ago #133431 by phillc54
A quick look shows:
net plasmac:axis-z-position axis.z.pos-cmd => plasmac.axis-z-position
should be:
net plasmac:axis-z-position joint.n.pos-fb => plasmac.axis-z-position
n being the joint number associated with the Z axis.
Also I don't see any [JOINT_n] sections in your ini file
EDIT: The line starting net plasmac:axis-z-position should be in your machine.hal file, that way it won't be overwritten on updates.
I have noted that in later updates.
Cheers, Phill.
EDIT:
If that doesn't work, I will try do them manually for you later on today. In the meantime do an update from the repo so I know what version you are using and can you confirm that your machine has three motors.
Last edit: 7 years 5 months ago by phillc54. Reason: typo and explanation
7 years 5 months ago #133460 by JTknives
I am so lost
I have no idea what a joint is. I never deleted anything just used the files and added my pins. I’m almost to the point where I want to completely format the computer and start over agian from scratch.
7 years 5 months ago - 7 years 5 months ago #133463 by JTknives
every time i update i get this error
twopass: Error in file ./plasmac.hal: Pin 'joint.3.pos-fb' does not exist Shutting down and cleaning up LinuxCNC... hm2_eth: HostMot2 ethernet driver unloaded hm2: unloading
If I go into the plasmac.hal I find this is missing any refrence to Z.
# inputs # the next line needs to be the joint associated with the Z axis net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position net plasmac:axis-x-position axis.x.pos-cmd => plasmac.axis-x-position net plasmac:axis-y-position axis.y.pos-cmd => plasmac.axis-y-position
but if I change that line to this the error goes away
Am i messing up here by changing this?
7 years 5 months ago #133468 by rodw
For that pin not to exist, it sounds like you are running the standard 2.7 version of linuxcnc.
A joint is a motor and you might have 2 of them on a single axis on a gantry machine...
Joints do not exist in Linux 2.7, only in master branch (2.8)
When you run linuxcnc from the command line do you see 2.8 showing up on the splash screen or not?
Make sure you are following the commands to set the rip-environment at the very end of the first post.
7 years 5 months ago #133472 by JTknives
yes I set the environment first and i do see the the 2.8 on splash and says like pre 1 or some such thing.
Time to create page: 0.079 seconds
