Configuring Plasmac - a complete THC/plasma config for any hardware
7 years 5 months ago #133506 by rodw
Looks like you are still missing stuff in your ini file for joints. Certainly the PID settings (eg the P)
Leave the spindle stuff there. I took mine out and had problems.
here is what I have in my ini for a typical joint
Warning: Spoiler!
I would concentrate on getting the non plasmac config working without errors, then copy it over. It does not take long.
I have found increasing these settings can get rid of following errors
# The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 450 STEPGEN_MAXACCEL = 5000
RodW
[url=https://mrrodw.au[/url]
Youtube
7 years 5 months ago - 7 years 5 months ago #133510 by JTknives
here is my original ini, i will try and compile it but i am really doubting my skills at this point lol
File Name: black_hole.ini
File Size:3.93 KB
Last edit: 7 years 5 months ago by JTknives.
7 years 5 months ago - 7 years 5 months ago #133511 by phillc54
Give this a try.
Cheers, Phill.
Edit: You may need to check the halfile name and machine name...
Last edit: 7 years 5 months ago by phillc54.
7 years 5 months ago #133512 by JTknives
thank you so much for your help. those errors are now gone but this popped up now.
twopass: Error in file ./plasmac.hal: Pin 'spindle.0.on' was already linked to signal 'spindle-enable' Shutting down and cleaning up LinuxCNC... hm2_eth: HostMot2 ethernet driver unloaded hm2: unloading Note: Using POSIX realtime LinuxCNC terminated with an error. You can find more information in the log: /home/jtknives/linuxcnc_debug.txt and /home/jtknives/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal jtknives@plasma:~/linuxcnc-plasmac$
7 years 5 months ago #133513 by phillc54
Comment out these lines in your machine hal:
line 233:
net spindle-enable => pid.s.enable
line 244:
net spindle-enable <= spindle.0.on
Cheers, Phill.
7 years 5 months ago #133521 by JTknives
Oh thank the lord, phill you are a god send. I am up and running and no errors. Thankyou all for all your help in this journey out of this black hole.
Time to create page: 0.271 seconds
