Configuring Plasmac - a complete THC/plasma config for any hardware
7 years 5 months ago #134003 by JTknives
thanks, i got it working. i figured it would not be a good idea to fire it up without an estop.
i also tied in the stepper drive fault back into the board. Took a bit of trial and error but i got it with this. I tried originally to use axis instead of joint as i found reference to doing it that way but i could never get it to work. am i doing this correctly or am i off base?
# ---Axis fault --- net axis.x.fault <= hm2_7i76e.0.7i76.0.0.input-13 net axis.y.fault <= hm2_7i76e.0.7i76.0.0.input-14 net axis.z.fault <= hm2_7i76e.0.7i76.0.0.input-15 net axis.x.fault => joint.0.amp-fault-in net axis.y.fault => joint.1.amp-fault-in net axis.z.fault => joint.2.amp-fault-in
7 years 5 months ago - 7 years 5 months ago #134005 by rodw
MIne's a bit more complex
# --- ESTOP CHAIN STARTS --- net latch-reset <= iocontrol.0.user-request-enable net latch-ok-in <= iocontrol.0.user-enable-out net latch-ok-in => estop-latch.0.ok-in net latch0-out <= estop-latch.0.ok-out net latch0-out => estop-latch.1.ok-in net latch1-out <= estop-latch.1.ok-out net latch1-out => estop-latch.2.ok-in net latch2-out <= estop-latch.2.ok-out net latch2-out => estop-latch.3.ok-in #net latch3-out <= estop-latch.3.ok-out #net latch3-out => estop-latch.2.ok-in net latch-reset => estop-latch.0.reset net latch-reset => estop-latch.1.reset net latch-reset => estop-latch.2.reset net latch-reset => estop-latch.3.reset net latch-out iocontrol.0.emc-enable-in <= estop-latch.3.ok-out net estop-out estop-latch.3.fault-out # --- EXTERNAL ESTOP SWITCH - CONTROL BOX--- net external-estop <= hm2_7i76e.0.7i76.0.0.input-00 net external-estop => estop-latch.0.fault-in # --- EXTERNAL ESTOP SWITCH - CONSOLE --- net console-estop <= hm2_7i76e.0.7i76.0.0.input-31-not net console-estop => estop-latch.3.fault-in # --- PENDANT ESTOP SWITCH --- net pendant-estop <= hm2_7i76e.0.7i76.0.0.input-26-not net pendant-estop => estop-latch.1.fault-in # --- TORCH BREAKAWAY E-STOP --- net torch-breakaway <= hm2_7i76e.0.7i76.0.0.input-06 net torch-breakaway => estop-latch.2.fault-in # --- E-STOP STEPPER DRIVE DISABLE --- net estop-out hm2_7i76e.0.7i76.0.0.output-05
I think I'd like to take the breakaway out of this chain and just make it pause the machine.
RodW
[url=https://mrrodw.au[/url]
Youtube
Last edit: 7 years 5 months ago by rodw.
7 years 5 months ago #134006 by islander261
Rod
If you have connected it correctly the Plasmac branch will handle torch break away well with the plasmac component. I have lots of experience with it now! I actually haven't lost a part since starting to use Plasmac. You do actually want it to pause and not put the machine into estop if you don't use Plasmac.
7 years 5 months ago #134039 by phillc54
Rod,
I have written a configurator to create a plasmac config. I have posted it in the Another plasma component and you may want to link to it in the first post.
Cheers, Phill.
The following user(s) said Thank You: billykid, tommylight
7 years 5 months ago #134374 by billykid
first of all thanks to those who are doing this good job.
I'm doing the first tests with a 7i80 + 7i30 + thcad 0-10, the motors work and the voltage is read .. I would like to know how to use this thcad mode 0 or 1? I also have the arc-ok signal that I used with an analog thc.
Thanks in advance
mauro
7 years 5 months ago - 7 years 5 months ago #134399 by rodw
The THCAD mode select (W1) should be down to select unipolar mode. This gives you a 0-10v range not -5v to +5v
You should also select the divider link to 1/32 and adjust your full scale frequency and offset accordingly (eg divide the calibration spec by 32)
RodW
Youtube
Time to create page: 0.323 seconds
