Configuring Plasmac - a complete THC/plasma config for any hardware
7 years 3 months ago #139342 by rodw
Bhushan wrote: sir i got plasmac easily as you suggested
just a minor question Why i cant see step and dir connections
MY QUESTION IS DO I NEED TO DO THEM MYSELF
Yes, the workflow is to get your machine working with basic xyz motion and acceleration rates set (follow the bit about external offsets in the plasma primer as well). Once it works (forget about cutting anything), run the configurator..
7 years 3 months ago #139356 by phoenix
Sorry but I didn't understand anything
I see step and dir signals connected to stepgen
Can i directly add parport pin in front of it???
7 years 3 months ago #139359 by phillc54
If you are using a parallel port based machine then I would suggest that you use stepconf to get your base machine working then add the PlasmaC configuration.
linuxcnc.org/docs/devel/html/config/stepconf.html
linuxcnc.org/docs/devel/html/plasma/plas...smac_to_base_machine
7 years 3 months ago #139404 by phoenix
As i said I'm not gonna stop posting untill i get appropriate ans thats why forum is made
I'm going furious
I wasted my whole weekend for plasmac and now its not even moving my machine beacause owner doesn't like simple things
I'm trying since 4 hours just TO ADD STEP AND DIR SIGNALS
7 years 3 months ago #139412 by tommylight
You keep ignoring help from other members, and ofending us will not help you.
7 years 3 months ago #139445 by snugglylovemuffin
My man, I've been there and yes it's very frustrating...
These guys will go above and beyond to help you out if you have patience.
Plasma machines have had very little support and you're talking to the only group of guys remotely interested in developing the tools for plasma machines. This is not an easy process and the learning curve is quite steep; read through their posts and see what you can glean before asking questions.
Time to create page: 0.467 seconds
