Low budget plasma setup, what do I need?
- Thank you received: 4155
09 Aug 2019 20:00 #141830
Replied by rodw on topic Low budget plasma setup, what do I need?
Very nice.
I think you need to change the title of this thread Bengt.
It does not look low budget anymore!
- pl7i92
- Thank you received: 359
10 Aug 2019 01:16 #141845
by pl7i92
Replied by pl7i92 on topic Low budget plasma setup, what do I need?
things get quickly out of budget if you get good information
you can build from 1k-1mio
very nice indeed
very nice indeed
- tecno
- Thank you received: 127
10 Aug 2019 11:01 #141867
by tecno
Replied by tecno on topic Low budget plasma setup, what do I need?
Thanks guys.
To me this is low budget as almost all parts are more or less to no cost. So far only stepper-motors, connectors, THCAD300 and PSU's have been thinning my slim wallet.
Next is to get all wired up and start testing the PC/MESA 7i90HD. Then it is time to have a look at PlasmaC and most likely I will need some advice from you guys.
Will probably shrink down my mechanical size to 500x500 as I do not have the space for the planned 500x 1000 that will be a bit heavy and cumbersome for an old fart like me to move from storage to cutting. More details to come but still same design.
- Thank you received: 7504
10 Aug 2019 11:31 #141872
Replied by tommylight on topic Low budget plasma setup, what do I need?
Two hinges can do wonders ! Bolt it to the wall and bring it down only when you need it, otherwise it stays there kissing the wall and out of the way.Will probably shrink down my mechanical size to 500x500 as I do not have the space for the planned 500x 1000 that will be a bit heavy and cumbersome .......
- pl7i92
10 Aug 2019 11:55 #141875
by pl7i92
- tecno
10 Aug 2019 12:13 #141876
by tecno
If it was that easy, I have no wall space to to that
I will have to make a stand that will be outside all year around and the CNC-frame to be stored inside when not in use.
- tecno
10 Aug 2019 12:16 #141877
by tecno
We will hopefully soon see what kind of EMI issues I will have.
10 Aug 2019 12:42 #141878
@tecno
Having a lot of "space" problems here, too.
- tecno
14 Aug 2019 09:04 #142115
by tecno
Need some help here, I can not get PC to communicate with my 7i90.
So what is wrong here?
Cheers
Bengt
bengt@plasma:~$ uname -a
Linux plasma 4.9.0-9-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.168-1+deb9u2 (2019-05-13) x86_64 GNU/Linux
bengt@plasma:~$
bengt@plasma:~$ dmesg | grep par
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.011091] AppArmor: AppArmor disabled by boot time parameter
[ 0.248159] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 1.574777] PM: Hibernation image partition 8:5 present
[ 4.868714] ppdev: user-space parallel port driver
[ 4.918583] PCI parallel port detected: 1415:8403, I/O at 0xec00(0xe880), IRQ 18
[ 4.918652] parport0: PC-style at 0xec00 (0xe880), irq 18 [PCSPP,TRISTATE,EPP]
[ 5.016213] lp0: using parport0 (interrupt-driven).
bengt@plasma:~$
bengt@plasma:~$ sudo mesaflash --device 7i90 --addr 0xec00 --readhmid
[sudo] lösenord för bengt:
ERROR: you must select transport layer for board
bengt@plasma:~$ So what is wrong here?
Cheers
Bengt
- Thank you received: 5337
14 Aug 2019 09:24 #142117
Replied by PCW on topic Low budget plasma setup, what do I need?
Well mesaflash is telling you in a rather terse way:
did you try mesaflash -- help ?
Time to create page: 0.211 seconds
