Low budget plasma setup, what do I need?
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
14 Aug 2019 14:31 #142119 by tecno
Replied by tecno on topic Low budget plasma setup, what do I need?
Yes and I can not find any explanation to *transport layer*.
If I insert --epp and try --addr_hi it still fails to clear times out
14 Aug 2019 14:44 #142120 by PCW
Yes EPP is a transport layer
Does the parallel port work with LinuxCNC?
  • tecno
  • Platinum Member
  • Platinum Member
14 Aug 2019 14:54 #142122 by tecno
How do I test that?
14 Aug 2019 16:00 #142126 by PCW
Probably the easiest way is to use halcmd
halcmd -f
halcmd: loadrt hostmot2
halcmd: loadrt hm2_7i90 ioaddr=[yourbase-address] ioaddr_high=[yourhigh_baseaddress] epp_wide=0 config = " "
and see if it loads
  • tecno
  • Platinum Member
  • Platinum Member
14 Aug 2019 16:32 #142128 by tecno
bengt@plasma:~$ halcmd -f
<stdin>:1: waitpid failed /usr/bin/rtapi_app hostmot2
<stdin>:1: /usr/bin/rtapi_app exited without becoming ready
<stdin>:1: insmod for hostmot2 failed, returned -1
bengt@plasma:~$
14 Aug 2019 17:10 #142131 by PCW
I would say something is broken in your LinuxCNC installation, I would expect this:
peter@dc7800:~$ halcmd -f
Note: Using POSIX realtime
  • tecno
  • Platinum Member
  • Platinum Member
14 Aug 2019 17:17 #142132 by tecno
Did update/upgrade
halcmd: loadrt hm2_7190 ioaddr=0xec00 ioaddr_high=0xe880 epp_wide=0 config=" "
hm2_7190: dlopen: /usr/lib/linuxcnc/modules/hm2_7190.so: cannot open shared object file: No such file or directory
<stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_7190
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hm2_7190 failed, returned -1
bengt@plasma:~$
14 Aug 2019 17:30 #142134 by PCW
What sort of base LinuxCNC installation are you using, it still seems broken.
Here's what I get:
halcmd: loadrt hm2_7i90 ioaddr=0x378
hm2_7i90: loading HostMot2 Mesa 7i90 driver version 0.3
hm2: no firmware specified in config modparam! the board had better have firmware configured already, or this won't work
hm2/hm2_7i90.0: 72 I/O Pins used:
hm2/hm2_7i90.0: IO Pin 000 (P1-01): StepGen #0, pin Step (Output)
hm2/hm2_7i90.0: IO Pin 001 (P1-03): StepGen #0, pin Direction (Output)
hm2/hm2_7i90.0: IO Pin 002 (P1-05): StepGen #1, pin Step (Output)
  • tecno
  • Platinum Member
  • Platinum Member
14 Aug 2019 17:47 #142137 by tecno
bengt@plasma:~$ uname -a
Linux plasma 4.9.0-9-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.168-1+deb9u2 (2019-05-13) x86_64 GNU/Linux
bengt@plasma:~$
I think I will install latest via Synaptic linux-latest_4.9+80+deb9u7 I assume this the latest? Isnt this needed for PlasmaC?
14 Aug 2019 17:54 #142138 by PCW
I was not so concerned with the OS but rather how LinuxCNC was installed, not being able to find driver files suggests something busted with the LinuxCNC installation
Time to create page: 0.410 seconds
