3.5X1.5 Meters cnc plasma cutter
- Thank you received: 7504
27 Oct 2019 14:10 - 08 Feb 2020 14:29 #148916
3.5X1.5 Meters cnc plasma cutter was created by tommylight
Last few days been working on this :
The machine dimensions are 4.2X1.75 meters, cut area will end up to 3.6X1.35 meters, so big enough.
Here are some details of the reductions on both sides:
Other side
Bottom part where the pinion and the big pulley are mounted, gutted two healthy Vexta 5 phase steppers to get the bearing holders and bearings that did the job perfectly:
This is how the frame looked yesterday:
Another shot of the reduction in place:
Regards,
Tom.
P.S.
Adding pictures to this topic also, later.
forum.linuxcnc.org/plasma-laser/35349-op...ea-and-a-lot-of-info
Video of moving gantry here:
Video of it cutting here:
Other side
Regards,
Tom.
P.S.
Last edit: 08 Feb 2020 14:29 by tommylight. Reason: add video link
The following user(s) said Thank You: phillc54, chimeno, Clive S
- thefabricator03
- Visitor
27 Oct 2019 15:00 #148923
by thefabricator03
Replied by thefabricator03 on topic 3.5X1.5 Meters cnc plasma cutter
Looking good so far Tom,
Cant wait to see it in action!
- machinedude
- Thank you received: 312
27 Oct 2019 15:18 #148924
by machinedude
Replied by machinedude on topic 3.5X1.5 Meters cnc plasma cutter
slightly bigger than what i have going on and it probably took you a week to toss it together compared to my 3 months of building
i'm amazed by the ability to toss it together so quickly.
27 Oct 2019 15:36 #148925
Took me 5 days to make room for it as i had to rearrange the shop, to many things, waayyyyy to many things to move and clean !
This is my right hand after two days of drilling and taping hundreds of holes:
Back to work, no slouching allowed !
Replied by tommylight on topic 3.5X1.5 Meters cnc plasma cutter
2 and a quarter days so far, full days from 10AM to 1AM!slightly bigger than what i have going on and it probably took you a week to toss it together compared to my 3 months of building
- machinedude
27 Oct 2019 15:43 #148928
by machinedude
at least you did not bust a finger tip like me so be thankful. i give you credit on speed of assembly. wish i was able to work like that sometimes.
- Clive S
- Thank you received: 486
27 Oct 2019 17:02 #148933
by Clive S
Replied by Clive S on topic 3.5X1.5 Meters cnc plasma cutter
Tom glad to see you got your mojo working again:)
27 Oct 2019 17:24 #148935
I quit the job at that factory, got tired of waiting for parts as they were miss handled by that Russian guy, for 3 years he did nothing!
I am to old to be waiting for anything any more!
28 Oct 2019 16:01 #149004
Here is a video of the gantry moving at over 30meters/minute.
The following user(s) said Thank You: phillc54, chimeno, thefabricator03
- thefabricator03
- Visitor
28 Oct 2019 16:51 #149008
by thefabricator03
What kind of power supplies are you using Tom? Are they switch mode units or torodial?
- machinedude
28 Oct 2019 17:08 #149010
by machinedude
any reason why it's running on the Z axis or is that just for testing movement until everything is configured and finalized?
Time to create page: 0.871 seconds
