My Newb Plasma Table Attempted Build
- Thank you received: 4155
23 May 2020 01:22 #168652
Lazy is good. Thats why the spaceship is not painted because its not finished yet!
I was looking at belts the other day and saw that some were not good for precision motion and had backlash but my mind is a seive so I've forgotten everyyhing except that a 10:1 reduction ends up with a 445mm pulley!
Replied by rodw on topic My Newb Plasma Table Attempted Build
Thanks Rod, I probably will make a reduction unless I stay as my my normal lazy self and change to GT2 but that may be a bit light. The other lazy option is to get a 16T 5mm bore and see what happens when the bore grows to 6.35mm.
- phillc54
- Thank you received: 2100
23 May 2020 03:03 #168656
by phillc54
Replied by phillc54 on topic My Newb Plasma Table Attempted Build
I told a lie, I have been working on the table and my pulleys are actually 16 teeth so that is 48mm/rev, not optimal but it wil do for a while.
I also managed to straighten the Z axis leadscrew to within 0.02 mm in the centre, it is 200mm long and was around .75mm out originally so I am very happy with that. It is amazing what you can do with some time, some blocks of wood and a hammer...
- Thank you received: 7506
23 May 2020 04:03 #168668
Replied by tommylight on topic My Newb Plasma Table Attempted Build
www.ebay.com/itm/Timing-Belt-Pulley-GT2-...UylA5wX-Ef5Vb2nrBVaw
I bought from him several times, everything is perfectly good with him, delivery, price, quality, all as it should be.
And this is by far the cheapest reduction set on the net.
23 May 2020 04:34 #168675
So how did you manage to bend a ballscrew?
- phillc54
23 May 2020 04:36 #168676
by phillc54
That was a case of you get what you pay for. From memory the complete Z axis was around AUD$70
- dvn4life1972
- Thank you received: 173
23 May 2020 08:08 #168686
by dvn4life1972
Replied by dvn4life1972 on topic My Newb Plasma Table Attempted Build
That's pretty cheap.
- phillc54
23 May 2020 18:41 #168747
by phillc54
Yes, and cheap is the operative word...That's pretty cheap.
- dvn4life1972
25 May 2020 17:48 #168912
by dvn4life1972
Well, just got back home from a visit to family. I went to cut a part out and the power went down for the shop for a moment. I can get the thing to start where it left off, right? I tried but I had to restart the software and need the torch to come on and probe, etc. Is there a decent procedure, or do I need to go into the gcode and add it at where I need it to run from?
- dvn4life1972
25 May 2020 18:29 #168917
by dvn4life1972
I tried inserting a M3 $0 S1 right before where it died and it worked and completed the cut. Phew I was nervous about that.
25 May 2020 18:55 #168919
For a short run, I just run it with the torch off until it catches up. Sometimes, I've edited the sheetcam job to remove already cut parts.
The following user(s) said Thank You: jay1st, dvn4life1972
Time to create page: 0.501 seconds
