Controller hardware suggestions for first DIY build
- txtrone
- Thank you received: 106
23 Sep 2020 01:24 #183367
by txtrone
Controller hardware suggestions for first DIY build was created by txtrone
I am looking for electronic hardware suggestions for my first DIY build. This build will be used to control a 4x4 plasma table. The table is currently equipped with four 300oz motors left over from a CandCNC system. There are no other electronics with this table, as I moved them to my new table.
Where to start? Seems like the Mesa 7i96 is super popular. I am feeling a bit overwhelmed, but don't want to haul off and buy something incompatible. Thanks in advance!
- Thank you received: 4151
23 Sep 2020 01:49 #183369
Replied by rodw on topic Controller hardware suggestions for first DIY build
Try this shopping list.
1 x Mesa 7i96,
1 x THCAD-5 (for 50:1 divider) or THCAD-10 for others,
1 x thcad-5 for ohmic sensing (Hypersensing)
Mesa DIN rail mounts
Mesa Common x 2 bus rail with their din Rail mount
1 x 2 amp 24v Meanwell DIN RAIL power supply for field power
1 x 2 amp or similar 5v power supply for logic
1 Meanwell HDR 15-24 isolated power supply for ohmic sensing
1 x 25 k 5 Watt resistor for ohmic sensing
1 x 390k resistor for ohmic sensing
3 x 90 ohm x 5 W power resistors for reliable arc OK
An IEC connector with built in RFI filter for mains power input
Stepper motor power supply to suit
Stepper drives to suit.
Mains fuse,
estop switch
Odroid H2+ with 4 gb RAM (8gb optional)
You might use some relays but really the 7i96 has them built in so there is no need to add more components and failure points.
1 x Mesa 7i96,
Mains fuse,
estop switch
The following user(s) said Thank You: txtrone
- txtrone
23 Sep 2020 01:59 #183371
by txtrone
What stepper drives would you suggest? My current CandCNC has Gecko G251s ... I think. What would you go with for stepper PSU and stepper drives?
I have a similiar PC that I plan to run Mint 19.3 on. I was thinking I should start by getting the motors to move properly before diving in any further.
Thanks again!
Replied by txtrone on topic Controller hardware suggestions for first DIY build
Mains fuse,
estop switch
Thanks again!
23 Sep 2020 02:04 #183372
I'm using Lam Technologies but I don't think there is a US supplier.
Paired with 64 volt AC toroid
do you have a link to a drive data sheet?
- txtrone
23 Sep 2020 02:12 #183374
by txtrone
- Himarc3D
- Thank you received: 49
23 Sep 2020 03:17 - 23 Sep 2020 03:18 #183383
by Himarc3D
Replied by Himarc3D on topic Controller hardware suggestions for first DIY build
The LAM documentation is really nice, if my machine work i pretend use it now im using cheap stuff from aliexpress
Last edit: 23 Sep 2020 03:18 by Himarc3D.
23 Sep 2020 04:18 #183389
Sorry, I should have asked for a link to motors. Mainly to work out the voltage you need.
www.geckodrive.com/support/g251x-rev-9.html
- txtrone
23 Sep 2020 13:33 #183468
by txtrone
All I see on the motor is '60HS66DF1T'
Their is not a whole lot of info about it on CandCNCs website either:
www.candcnc.net/store-home/300oz-motor/
23 Sep 2020 19:59 #183510
Normally if a motor has no data sheets, I'd say buy another motor but heck you have got them now.
I would probably get Longs Motor DM542A drives
The G251x is limited to 50 volts. So get a 10 amp 48 volt Meanwell Switch mode power supply.
I know those drives work well and are hard to kill as I originally used them on my machine. I ran them with a Mesa card with 20x stepping
If you still have the G251's see if you can measure the current limiting resistor to see what amperage they were running the motors at and set the drives up for that. at a guess, they will be in the 2.8 to 3.2 amp range.
- Clive S
- Thank you received: 486
23 Sep 2020 21:55 #183516
by Clive S
I would not use 48V on a 50V drive. The back EMF could kill them.
40v would be safer. Just my opinion
Replied by Clive S on topic Controller hardware suggestions for first DIY build
Time to create page: 0.257 seconds
