Controller hardware suggestions for first DIY build
- txtrone
- Thank you received: 106
24 Sep 2020 22:37 #183638
by txtrone
Replied by txtrone on topic Controller hardware suggestions for first DIY build
Thanks for the input! I am at the point I have to just go for it.
- txtrone
24 Sep 2020 22:39 #183639
by txtrone
Will do. I look forward to making turning some motors.
- txtrone
24 Sep 2020 22:55 #183642
by txtrone
Hmmm. Should I start another thread asking about what drives I should get? I have a lot of questions about that as well. Getting the PC loaded up with LinuxCNC was priority. Next I want to get the motors turning properly. I am open to try some other drives. KL model drives have been mentioned. Any others I should look at?
I agree, the first time the machine stops abruptly, it will kill the drive.I would not use 48V on a 50V drive. The back EMF could kill them.
40v would be safer. Just my opinion
Gecko uses 100V MOSFets on 80V rated drives so i have seen plenty of them go up in smoke, but i never managed to kill one of them as they do mention on their web site and provide the schematics for wiring a power resistor and a relay to prevent from killing the drives. I have yet to see some one else use that. I know i did.
- txtrone
24 Sep 2020 23:07 #183643
by txtrone
Ok, so far I ordered a Mesa 7i96 and some DIN rail and one Gecko 251x to make sure I could get that much to work before I hauled off an bought the entire list.
I also ordered these power supplies:
-Mean Well USA MDR-60-24
-MDR-10-5
-HDR-15-24
-NDR-480-48
For the PEM I ordered this one:
www.alliedelec.com/product/schaffner/fn9264-10-06/70254153/
Is this the item you suggested, if so do I need just one of these and one of the din rail mounts for it? They sell the din rail adapter mounts in packs of 2 or 3.
store.mesanet.com/index.php?route=produc...id=230&search=common
I am holding off on the resistors and THCAD for the moment... just until I get the motors moving properly. Thanks again!
Try this shopping list.
1 x Mesa 7i96,
1 x THCAD-5 (for 50:1 divider) or THCAD-10 for others,
1 x thcad-5 for ohmic sensing (Hypersensing)
Mesa DIN rail mounts
Mesa Common x 2 bus rail with their din Rail mount
1 x 2 amp 24v Meanwell DIN RAIL power supply for field power
1 x 2 amp or similar 5v power supply for logic
1 Meanwell HDR 15-24 isolated power supply for ohmic sensing
1 x 25 k 5 Watt resistor for ohmic sensing
1 x 390k resistor for ohmic sensing
3 x 90 ohm x 5 W power resistors for reliable arc OK
An IEC connector with built in RFI filter for mains power input
Stepper motor power supply to suit
Stepper drives to suit.
Mains fuse,
estop switch
Odroid H2+ with 4 gb RAM (8gb optional)
You might use some relays but really the 7i96 has them built in so there is no need to add more components and failure points.
-MDR-10-5
-HDR-15-24
-NDR-480-48
- BeagleBrainz
- Visitor
24 Sep 2020 23:57 #183650
by BeagleBrainz
Replied by BeagleBrainz on topic Controller hardware suggestions for first DIY build
I was just reading a pdf regarding controls panels & noise. The recommendation was to have a separate noise filter placed physically close to each switching PSU, as they can create a bit of noise. Linear power supplies aren't as "noisy" but are a little larger. The documents is geared for industrial situations but it makes for an interesting read.
literature.rockwellautomation.com/idc/gr.../gmc-rm001_-en-p.pdf
On the driver I'm using for my AC servo motor spindle the manufacturer recommends a noise filter for the power terminals for the drive's motor circuitry & a separate noise filter for the drive's logic circuitry. As well as an single phase AC line reactor.
- txtrone
25 Sep 2020 00:54 #183660
by txtrone
That is basically how my 'main' rig is setup. I think Tom at CandCNC gave me that advice. Thanks for sharing the pdf.
The following user(s) said Thank You: BeagleBrainz
- txtrone
26 Sep 2020 18:22 #183864
by txtrone
I finally got my hands on this.
www.geckodrive.com/support/g251x-rev-9.html
Sorry, I should have asked for a link to motors. Mainly to work out the voltage you need.
- txtrone
26 Sep 2020 19:23 #183871
by txtrone
Do you mean I need 2ea of the THCAD-5? I am using a Hypertherm Powermax 85
- Thank you received: 4151
26 Sep 2020 20:38 #183880
Yes. 50:1 will give a maximum scale of 250v to cover the useful cutting range but the THCAD-5 can handle 500v indefinitely for safety.
And also yes, grab the Mesa common connector you linked to. You can connect your 24V logic power + and - to the separate halves and then you can patch the power to wherever you need to for any inputs or outputs. It makes for a very compact design.
Replied by rodw on topic Controller hardware suggestions for first DIY build
- snowgoer540
- Thank you received: 907
26 Sep 2020 20:50 #183881
by snowgoer540
If you don’t mind taking it apart and switching it to 20:1, I’d use (and PCW recommended) that divider setting and a THCAD-10. It gives you 0-200v range where your max cutting voltage is somewhere around 150-170v. They all have the same 500v over voltage. So that combo gives the highest resolution.
Replied by snowgoer540 on topic Controller hardware suggestions for first DIY build
Time to create page: 0.190 seconds
